Old 02-03-2013, 12:39 PM   #1
Dale99
Ball Joint, tips advice?
I'm about to go outside in an hour and start taking the front axle apart to replace ball joints. I was wondering if there are any tips or advice? It is a 72 1/2 ton.... so dana 40?
I do understand the axle needs to come out before I can knock the spindle off. Do I need to pull the diff cover and undo anything before the axle comes out? If not, when I pull the axle out, should any gear oil come out the axle tube and need a tub to catch it?
Any other tips?
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
