Stripped door sill step plate screws. How to remove?
I'm replacing my door step plates, but the blasted screws are not playing nice. There are about 5 Philips screws on each. On one side, all are seized up. On the other side only one is.
So, how do I get these off? I've tried PB Blaster, but it didn't help ![]() Posted via Mobile Device |
Re: Stripped door sill step plate screws. How to remove?
Search for "Grabit Tool"
I have a set and they work on stripped screw heads preety good. There are 4 different sizes in the set but don't forget to run your drill in reverse while making the pilot hole and extracting. |
First thing to do is pit screw driver on screw,then tap straight down with a hammer. Now try the screw.
On the underside,use a vise grip to break loose (once the PB Baster has soaked). Once turned loose,screw them tight gain,cut the screws off from behind,and remove with screw driver
Spray the underside also. Try grabbing with a good set of pliers or vise grips.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
die grinder with a thin cut off wheel put a slot in it then get a straight screwdriver on it worked for me a bunch of times
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#6 | |
Oh man,and I meant to say "put" not "pit". But it worked anyway!
