Old 02-03-2013, 04:01 PM   #1
jd7
jd7's Avatar
booster & master question
My drivetrain is road worthy,now for the brake system. I have a 69 C10 shortbed drum brakes 6 lug, junkyard master & booster from p.o. I have a CPP 5 lug axle conversion kit, and CCP drop spindles. I went with the 1978 rotors,calipers,pads, and 1972 drums for the rear.My question is will a master & booster combo from a 1978 bolt up without fabrication or hardware changes ? also what year proportioning valve will I need ?I purchased the items from CCP that I had to, the other parts were top brand aftermarket.I am a mechanic by trade so I payed cost on everything else. thanks
jd7 is offline   Reply With Quote
Old 02-04-2013, 12:14 AM   #2
jd7
jd7's Avatar
Re: booster & master question
Old 02-04-2013, 07:44 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
A 71-72 M/C would be a bolt on swap.
A 71-72 prop valve would also be a direct swap.
The 73-87 version would work,... but You will have to plug 1 extra front brake line port.
I would look at aftermarket parts also,...
http://www.performanceonline.com/60-...ts-components/
Keith
Convert to disc brakes.
Old 02-04-2013, 10:00 PM   #4
jd7
jd7's Avatar
Thank you very much Keith... you have answered many if not all of my questions. I do electrical, and computer diagnostics. If ever you need advice feel free ask
