Old 02-03-2013, 05:05 PM   #1
fastnloud
fastnloud's Avatar
Help with bumper bolts?
I'm trying to change the front bumper on my 82, and the bolts have these chrome button looking things on top of them. How do you get the bolts out of these bumpers?
Thanks guys.
fastnloud is offline   Reply With Quote
Old 02-03-2013, 05:12 PM   #2
rwhit57
rwhit57's Avatar
Re: Help with bumper bolts?
They are a carriage style bolt with the square shoulder that sits in a square hole, take care in removing them and always keep the head end against the bumper to keep them from spinning.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 02-03-2013, 05:15 PM   #3
fastnloud
fastnloud's Avatar
Alright thanks, how do you go about removing the bolt?
Old 02-03-2013, 05:22 PM   #4
ont_guy_38
ont_guy_38's Avatar
When you remove the nut from the back the bolt just pulls out.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 02-03-2013, 05:51 PM   #5
wyattglock
wyattglock's Avatar
Depending on the condition of the hardware, you might have to cut them off and get new bolts. Thats what I had to do on my 89. Fortunately, LMC has the stainless bolt kit to replace the factory bolts. If the bolts aren't rusted to the nuts, then make sure you keep the head of the carriage bolts against the bumper or they will just spin.
wyattglock is offline   Reply With Quote
Old 02-03-2013, 05:57 PM   #6
rusty76
rusty76's Avatar
Most of the ones I've taken off break. But no big deal though. They're basically just carriage bolts anyway.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-04-2013, 03:38 AM   #7
Pop's C-10
Pop's C-10's Avatar
there is a nut on tha backside of tha bumper...slide under there & look & it will be clear how it comes off
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-04-2013, 03:47 AM   #8
Nin92
Nin92's Avatar
I definitely suggest using some WD40, fairly easy to spin the carriage bolt through the bumper material if its locked up.
Nin92 is offline   Reply With Quote
Old 02-04-2013, 03:55 AM   #9
dieseldawg142
dieseldawg142's Avatar
if their heavily rusted or have damaged threads, i've found it easier to unbolt the bumper brackets & then cut off the bolts to avoid damaging them square holes
dieseldawg142 is offline   Reply With Quote
Old 02-04-2013, 10:00 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
slow but,you can drill them ,if it's more important not to damage the bumper
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-04-2013, 10:13 AM   #11
57ToyBox
57ToyBox's Avatar
In my experience you have one chance to take those carriage bolts off without striping that square shoulder of the carriage bolt or rounding the square hole of the bumper.
I quickly heat the nut. With a helper putting pressure on the head of the carriage bolt with what ever is handy ie: hammer head or a 2x4
I gently back the nut off.
If it does spin? Your left to have to burn them off
57ToyBox is offline   Reply With Quote
Old 02-04-2013, 10:38 AM   #12
Wazup
Try some Rust Buster and let it sit then More and work the nut slowly back and forth as you undo the bolt ..
Wazup is offline   Reply With Quote
Old 02-04-2013, 11:01 PM   #13
willett
Another Day, Another Dollar
willett's Avatar
Break them. Buy new ones.
I recommend tightening them to death if they start giving you trouble on the way out. Don't wanna strip those holes
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-05-2013, 12:08 AM   #14
fastnloud
fastnloud's Avatar
Thanks guys for the info. I don't have any tools to cut them with, but I'll probably get one of the guys that does some other work on the truck for me to get them out.
Can you get the replacement bolts at an auto parts store?
Old 02-05-2013, 03:39 AM   #15
andrewmp6
Its probably cheaper to order them online tho.
andrewmp6 is offline   Reply With Quote
Old 02-05-2013, 08:44 AM   #16
Wazup
You can get a Bumper Bolt kit that has the Carriage Bolt with the cap and the lock washers and nuts for 19.95 from LMC Trucks .
www.LMCtruck.com
Old 02-05-2013, 09:14 AM   #17
riz
I had to use my grinder to cut an "X" into the rounded face of the bolts then bust them out. New carriage bolts are cheap.
RIZ
riz is offline   Reply With Quote
Old 02-05-2013, 11:13 AM   #18
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Mine came out without a problem on my 77. Spray some penetrating oil on them and wait a day. Pretty rusty, but came out without a problem.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
