Old 02-03-2013, 05:07 PM   #1
mlevario99
Exclamation Wiring Question
I have a 5.3 in a 66 chevy truck. I am using a fuse block from CURRENT Performance, I have used the same fuse block in another swap. Here is the problem, if I remove the ignition power relay and I turn the key to the on position, I have power to the relay socket on the battery side and on the pink/black wire coming from the 12v source, as soon as I install the relay in the socket, I do not have power on the pink/black wire, I have had this problem before, but it fixes on its own, so I do not know what to do. Any help please
mlevario99 is offline   Reply With Quote
