Old 02-03-2013, 05:34 PM   #1
BAMO
Heater Removal
Trying to remove the heater from my 65. believe it is the deluxe heater. Removal from the firewall seems easy enough (can see all the screws), but are there some screws under the dash I need to remove first?
Frank
http://backyardbuilt.tumblr.com
BAMO is offline   Reply With Quote
Old 02-03-2013, 06:34 PM   #2
travz500
travz500's Avatar
Re: Heater Removal
yes there is 3 around where the square part of the inside heater duct hooks to the firewall then there is 2 more studs sticking thru may be hard to see if insulation is there but there are 2 studs that are attached to the outside part of the heater box take the nuts off and it all comes off hope this helps
travz500 is offline   Reply With Quote
