Frame Question
Ok guys I'm at a stopping point here. As some of you may know i got the front frame section of an 85 1/2 ton 2wd chevy from my step father for parts to do the disc brake upgrade to my 64 gmc. So today after i cleaned the garage up from all the other stuff I've been doing. I drug the frame section in to the garge. Now i have started the tear down. I have remove all the steering, the brake lines, the calipers and rotors, and the backing plates. Now all i have left is the A arms and spindles. Now being as there is not enough wieght to the frame what is the easyest way to remove the A arms? I have the frame sitting on jack stands. I know if they were on the pickup all you have to do is jack the A arm up and undo the lower ball joint. But with no wieght on the frame how do you do that? Can i just undo the 2 U bolts or will that make a no so good plan.?
I'm stuck here can some one help me out? And no im not goin to put the whole cross member under my truck. I'm just after the A arms, spindles, brakes, swaybar, and steering linkages. Posted via Mobile Device
1964 ![]() |
#2 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Frame Question
Why did you choose to not go the easy route and just roll yours out and roll the newer one back under? Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#3 | |
Re: Frame Question
1964 ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Frame Question
What I've done in a situation like that is, first loosen the nuts on the ball joints, and back them off, but not all the way. Leave them on 2 or 3 threads of the ball joint stud. Then use either a ball joint seperator, or pound on the side of the spindle with a 3-5# hammer, until the stud releases. Now with the crossmember and all in the right side up position, remove the nuts on the LCA shaft U-bolts. Just do one side at a time, and one nut at a time on each U-bolt. When you do this, be very careful, and be prepared for the LCA to hit the floor hard. The whole crossmember may jump up a bit as well. As an extra precaution, prior to unbolting the U-bolts, you can run a chain thru the spring and the LCA, so that the spring can't go very far, should things get a little crazy on you.
Above all be very careful, and do not allow anyone else in the vicinity while you are doing this.
Re: Frame Question
Heres the pics. Frame section and the 71 booster i was givin and the the sail panel bling.
1964 ![]() |
#6 | |
Re: Frame Question
1964 ![]() |
Re: Frame Question
Or a really strong ratchet strap. Or you could try cutting the coils with a torch before unbolting and that will relieve a lot of the tension.
#8 | |
Re: Frame Question
1964 ![]() |
#9 | |
Re: Frame Question
1964 ![]() |
#10 | |
60-66 Nut
Re: Frame Question
If your '64 is a 1/2 ton, youe original crossmember will already have the saddles for the lower control arm shafts. You will want to upgrade to the newer and larger LCA U-bolts though.
If your '64 is a 3/4 ton, you will have to change your original crossmember to the newer one from your donor. The '60-'63 3/4 tons use a flat LCA shaft, so there are no saddles for the round LCA shafts. Quote:
#11 | |
Re: Frame Question
I do have a question about the brakes. If i use a 71 manual master cylinder for dics/drums. Do i still need the porpotion valve?
1964 ![]() |
Re: Frame Question
Yes you will still need the prop valve unless you are changing all four to disc brakes. (I assume you mean the bios out of the donor)
I have thought about the same mod on my '66, but I was going to bolt the whole thing on. What parts are you changing out? Just the spindles? Looks like fun.
Jon S 1966 GMC Suburban 305 V6 Las Vegas NV |
#13 | |
Re: Frame Question
If you can support your motor or its not in your truck I'm sure it a lot easyer to just use the whole member. But i have no way of doing so with out borrowing tools. Posted via Mobile Device
1964 ![]() |
#14 |
Re: Frame Question
Caution is the operative word. They can come loose and hurt you, so try to make sure you know what is going to happen when they let go, cause there's no time to duck.
Keep us posted. PS: Grew up in Nebraska, came to Kansas for 3.2 beer and fireworks.
#15 |
Re: Frame Question
I got it all apart tonite. Then hauled off what was left to a buddys shop. I will try and post pics tomarrow.
The other thing i got done tonight i changed out my a vacume port on my intake so i could test out the 85 and 71 brake boosters. Well I'm sure the 85 booster is bad. When i hooked it up with the engine running it ran ruff. But when i hooked up the 71 booster it smoothed out some but not as smooth as me pluging off the hose with my finger. It was easy to push the rod in but i didn't like how it didnt smooth out. So is the booster bad? Posted via Mobile Device
1964 ![]() |
#16 |
60-66 Nut
Re: Frame Question
Sounds like the '71 booster may have a leak in it.
#17 |
Re: Frame Question
Thats what i was thinking. thanks.
1964 ![]() |
#18 |
Re: Frame Question
I painted things so i know how many spacers and were they went for when i go back together. And i did remove the lower A-arm mounts just to be sure that is why they are painted also.
1964 ![]() |
#19 |
Re: Frame Question
ok so tonight i just hooked the hose to that 71 booster and sucked on it. Lol. I could hear air goin in to the rear of the booster were the rod from the pedel goes in so im pretty sure its got a leak. So now I'm on the search for a differant one. Just for the hell of it i was looking at the master cylinder we have at work. I found a remaned one part number r101264. Looked up the number on the net and it says its for a 77-82 vette. It has a shallow hole and a 1 1/8 bore. So if i can't find a booster i may just use that master cylinder and run manual breaks for now.
Do you know what booster would work with that MC other then the what i said it was for? Posted via Mobile Device
1964 ![]() |
#20 | |
60-66 Nut
Re: Frame Question
Pretty much all GM boosters made from '71-'99, or even beyond
#21 |
Re: Frame Question
Thanks captainfab. I think i may be able to get a booster off of a 99-01 s10. Not sure of year yet. Any way its been wreaked and he only wants $20 for it so its worth a shot! If i get it and its good i'd like to buy one of your brackets. I'll let you know. And thanks for all the help.
1964 ![]() |
#22 |
Re: Frame Question
Well i went and tryed to get the booster out of the truck. Well long store short i have one darn bolt left and i can't get to it with out braking or drilling a hole in the darn column mount!! So as made as i was i just sayed forget it for the night! I did look at the year and its a 2000 s10 and i pulled the hose off the intake and sucked on it and it seems like a good booster. It held vacume till i pulled the hose off and it sucked air back in to it so I'm guessing its good.? Sound right?
A lot of work for a $20 booster!! Lol! Posted via Mobile Device
1964 ![]() |
#23 |
I got the booster out of the 2000 s10 to night. I had to drill a hole through the steering column bracket to get to the last bolt. The bolt patern is the 3 3/8 x 3 1/2 so it should work with your bracket captainfab. My only question is the push rod between the master cylinder and the booster is a little differant then the 85 and 71 c10 ones. The little metal piece doesnt come out of the inch round center piece. But that whole center piece comes out? That shouldn't matter though right? It should still work with that 77-82 vette master cylinder right?
And id like to know how to get ahold of you to get one of your booster brakets. Thanks again for your help. Posted via Mobile Device
1964 ![]() |
#24 | |
60-66 Nut
Re: Frame Question
The intermediate pushrod should be fine. Are you using the Vette master cylinder because you have 4 wheel disc brakes?
I'll send you a PM with purchase information. Quote:
#25 |
Re: Frame Question
No because i can get it cheep. And its the same style as what a lot of the cpp kits come with. I'm sure i can get one for the 67-72 just as cheep. So i guess it realy don't matter as long as its a duel one.
1964 ![]() |
