02-03-2013, 11:19 PM | #1 |
Tire Swing Photos
Hey everyone Just bought a Tire swing for my 72Blazer and would like to get it properly mounted in its factory position. I did see the post of the tire swing schismatic that was posted on this site . It was just to many squiggly lines and to faded out to really read. What I could really use would just be some photos with a tape measure going down the side where it bolts up at. That way I could get a good measurment from the body lines to where to drill my holes . Also a measuring photo going across the tailgate to see where it latches up . Could use one more photo of the inside of the tailgate ... If I could get a team effort on this photos it would be greatly appreciated.
Thanks Everyone ! |
02-04-2013, 06:05 PM | #2 | |
Re: Tire Swing Photos
Gary 1971 K5 Blazer 350 V8 |
02-05-2013, 01:45 AM | #3 |
SKINNY TIRES RULE!
It should line up. The brackets are curved to fit the bed wall. The tail gate bracket should only fit in one spot. If you put it together and have a buddy or two hold it in place you should get an accurate alignment. You might put some blue tape on the body so you don't scratch the truck and you can mark the location.
Here's some photos of my swing away I have on my computer - sorry no measuring tape.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
02-05-2013, 08:02 PM | #4 |
Thanks for your photos
Posted via Mobile Device |
02-06-2013, 06:52 PM | #5 |
Where'd you get the tire swing?
02-07-2013, 08:07 AM | #6 |
Ray,
There will need to be a trunion type piece which mounts through the tailgate for the latch to latch onto, and two backing brackets that go behind the upper and lower hinge mounts. The upper one has a rod welded to it so that you can reach and hold it up in back of the top hinge to get bolts started in it (both brackets are tapped). Unfortunately, I don't have photos any longer from the one I took off my Blazer and sold.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
02-07-2013, 02:37 PM | #7 |
I have found not much use without special inside parts anyone know where to find them?
02-08-2013, 12:38 PM | #8 |
SKINNY TIRES RULE!
The brackets that go inside the bed wall are crucial to getting these things mounted. There are no repops and getting them produced can be expensive because they have compound curves to match the shape of the bedwall. Your best bet would be to post a wanted to buy thread. Sometimes when the swing away is removed, the brackets stay inside the bed wall, especially the upper that requires removing the taillight to access it.
I had photos of the brackets too, but it appears they are no longer on my computer.
02-08-2013, 08:51 PM | #9 |
Thanks again you guys ... Anyone else have any photos to share on this thread?
02-12-2013, 08:44 PM | #10 |
Here's some pics of the inner brackets. The top one has a rod welded from the factory so you can send it through the side maker light hole and up to the top of the quarter.
02-12-2013, 08:56 PM | #11 |
Great photos of the inner brackets Warbucket ! Anyone else have some photos to share of the complete set up taken out and photographed ?
02-12-2013, 09:01 PM | #12 |
Hey bouncy truck . Could you send a photo of your tailgate with your tire swing opened up and shut . I'd like to see how it latches and unlatches.
02-12-2013, 09:10 PM | #13 |
And some more of the location and one looking up the quarter at the rod.
02-12-2013, 10:54 PM | #14 |
SKINNY TIRES RULE!
I can't get the truck out of the garage right now - it's all packed away for the winter. I may have some more photos on my other computer - I'll dig around.
02-14-2013, 01:28 PM | #15 |
Here are some photos of mine, the make of it is different than any other I have seen around, its for sale by the way......$200 plus the ride
72' CST K5 Blazer |
02-14-2013, 07:33 PM | #16 |
Ok thanks again bouncy .. I hope to see some photos later. Also thank you Warbucket for busting out the tape for me I appreciate that, ... We're these holes factory drilled or no ?
02-14-2013, 08:45 PM | #17 |
Your welcome, they are factory bolt holes.
02-19-2013, 07:17 PM | #18 |
I believe that the tire carrier was a dealer installed accessory - not a factory installed option. Someone can correct me if I am wrong.
