Trim question
My 72 is missing some trim. I notice the top has no holes where it was mounted meaning the stick on mounts I've seen. Assuming I should go with the push in type. Or do the stick on clips work ok??
72 GMC super custom. ![]() |
Re: Trim question
Other question is we're they common on 72's
![]() Join Date: Jul 2007
Re: Trim question
thats how they did those. two push ins front and rear, and stickys in between.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
Active Member
![]() Join Date: Nov 2012
Re: Trim question
They were on the Cheyenne models which your paint scheme seems to be....
67 C20 283/4 Speed |
Re: Trim question
It's a gmc super custom if that means anything
Roadtrip!
![]() Join Date: Feb 2003
Re: Trim question
I think 71-72 went to the stick on clips. The trim could be had on any model if ordered.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Trim question
I was assuming they used stick ons on the later models like 72 Hoping the 72 parts truck is stick on so the trim will come off easier.
Re: Trim question
'69-'70 used bolt on/push in clips the whole way and '71/'72 got bolt ons for the ends and tape for in the middle. If you are building a show truck, I recommend the bolt on/push in because they pull the trim in tighter. If the tape is thicker or very spongy, there can be an unsightly gap in the trim.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
Re: Trim question
^ awesome just what I was looking for tape would probly promote more water to sit there and start rust too. Thanks
Re: Trim question
The donor truck hope the trim doesn't fight to much Posted via Mobile Device
Re: Trim question
Still making my mind up on the bottom trim Posted via Mobile Device
#12 | |
Moderator
![]() Join Date: May 2007
Re: Trim question
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
