Old 02-04-2013, 02:06 PM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
bending brake line
So how do i get a 90 bend with out kinking my lines... Grrrr
i have a tool that makes the bends but for some reason im not doing it right or this tool suck...
Sick5 is offline   Reply With Quote
Old 02-04-2013, 04:42 PM   #2
kerber63
kerber63's Avatar
Re: bending brake line
Plug one end of your line, then fill the line with sandblast media, or sugar. Then plug the open end and bend. No kinks. Remember to flush the lines before you install them!
kerber63 is offline   Reply With Quote
Old 02-04-2013, 09:53 PM   #3
jayoldschool
Moderator
One of my favourite tools for bending line is an old front disc brake rotor. You get three different radii (the outside of the rotor, the hat, and the hub), and you can also put the line in between two lugs and use that as a jig to bend against. Works like a charm.
jayoldschool is offline   Reply With Quote
Old 02-04-2013, 10:48 PM   #4
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Wow great idea guys. I might try both.
Old 02-04-2013, 10:52 PM   #5
Bugeyev8
Bugeyev8's Avatar
old crank pulley from a sbc with v belts works good too, but get a quality bender...much better
Bugeyev8 is offline   Reply With Quote
Old 02-05-2013, 02:07 AM   #6
Captainfab
60-66 Nut
I recently had trouble bending the line that is supposed to bend earier, without kinking. Of course I was bending a 180, but still on a 90 it didn't look all that good. And yes I was using a tube bending tool....unfortunately it is a HF POS. I ended up going to NAPA and I happen to find a length of the old style galvanized line, and it bent perfectly.
Old 02-05-2013, 10:56 AM   #7
65Gregg
65Gregg's Avatar
Try Poly Armour lines
http://www.agscompany.com/automotive...es/poly-armour
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-06-2013, 02:42 AM   #8
Captainfab
60-66 Nut
That is the type that I had trouble with the 180* bend kinking.
Old 02-06-2013, 04:12 AM   #9
argonaut
argonaut's Avatar
I've made a lot of custom lines from 3/16" to 3/8" in stainless and coated steel using only basic small and medium diameter bending tools and never ever had any problems kinking it. What are you using to bend them with?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-06-2013, 04:44 AM   #10
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I was just about to say the same thing.
I have a basic MATCO Bender tool.... Never had a problem.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-06-2013, 08:43 AM   #11
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Your basic two hand 180 bender.
Old 02-06-2013, 11:48 AM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Yeap that should do it ..... I have pretty decent results with mine:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 02-06-2013, 12:37 PM   #13
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Maybe im just doing it wrong
Old 02-06-2013, 12:48 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
If you're using the new coated green or black stuff, the tubing is the problem. I've been bending and forming steel tubing since the 1960's using a variety of tools both cheap and expensive. I've left off a few fittings from time to time, but I've never kinked a tube until that new stuff came along. I have expensive English roller benders and every time I've tried that new stuff it kinks. Addtionally, I cannot form a straight flare using the same flaring set I've had for at least 25 years.
Some people love the new stuff, and perhaps if you bend it over your knee and don't need to cut and reflare, it might be okay. But I'll never use it again. I recently bought several new pieces of the old galvanized stuff at Napa. They have it in the warehouse if not in the local store.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-06-2013, 12:59 PM   #15
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Thanks Markb01
This weekend ill change the tubing I buy and see if that helps
Old 02-15-2013, 11:03 PM   #16
shawno72
C/10 junkie
shawno72's Avatar
Any luck with this?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-15-2013, 11:08 PM   #17
lolife99
67-72 parts collector,…
lolife99's Avatar
Lots of info on Youtube.
Keith
Convert to disc brakes.
Old 02-15-2013, 11:48 PM   #18
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Good info
Old 02-16-2013, 02:21 AM   #19
Brad54
Brad54's Avatar
I'm glad I'm not the only one who's had horrible experiences with the new "easy bend" stuff! I hate that crap, for all the reasons you mentioned.
They're expensive, but you just can't beat an Imperial tubing bender for brake lines... 180-degree bend with the radius of a quarter.
And I've got a good Blue Point tubing cutter and flaring kit that has NEVER made a bad flare in the 25 years I've had it.
I've used all different kinds of tubing cutters, and that Blue Point is the only one that I've found makes a good, reliable, repeatable square cut. And it doesn't work-harden the end.
I'm not a big Tool Truck Tools fan, but that kit is worth every penny.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-16-2013, 09:10 AM   #20
shawno72
C/10 junkie
shawno72's Avatar
Great info guys.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
