Old 02-04-2013, 07:16 PM   #1
biohazardbill
Ride Tech e3 CPU mounting?
Where are some areas you guys have mounted your ECU? In a perfect world I would mount it with the compressor/tank etc are however they are located in the spare tire area of my build (step side with tire carrier so no under bed tire needed). Being that far back the front sensor wires will not reach. I had thought about under the seat, but that is a huge hole to drill in the floor for all the wires and under the seat would hide the excess wire. So I figured I would ask you pros where you mount yours?
Thanks in advance.
biohazardbill is offline   Reply With Quote
Old 02-04-2013, 10:42 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Ride Tech e3 CPU mounting?
I got one of these nifty little boxes from Porter Built and mounted it under the front driver side of the bed. The box holds the valves and extra cable. The tank is back in the spare tire area. Only the yellow wire (switched ignition) and the cable for the display go into the cab.
I relocated the battery on the opposite side which made it easier to run power for the compressors and the E3.
Zoomin is offline   Reply With Quote
