![]() Join Date: Aug 2007
69 Chevelle Fuel Tank Install
Installed the new tank on my son's 72 lwb with coils.... also put on new bumper and painted the frame a little along the way, lot's of pics too.....
Re: 69 Chevelle Fuel Tank Install
I used some adjustable tie down straps to mock it up, proved really helpful in being able to re-position the tank and I must have changed that 6-8 times....
From these pics you can see that my filler neck is going to be too high with the tank flush up against the frame. My goal is to have this tank as high as possible, so I don't want to space it down.... the third pic is the space I'd have if I have the neck lined up as is....
I cut the filler neck and got rid of the upward bend....
C/10 junkie
This tank doesn't hang down very low does it?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
You may notice the tank in different positions... I at one point had it even with the end of the frame rails and decided I wanted a little more space from the bumper and the tank. I would not recommend buying the straps that are designed to mount the Chevelle tank as they do not work on their own.... I got 2 4' straps and a piece of angle iron from Home Depot for $23..... that roll of stuff is camper tape that I used instead of the cardboard type anti squeak....
Here are some pics of the license plate bracket and flipdown bracket
Last few pics for now, you can see that the tank does not hang too low... this truck is stock height for now, but will end up with a 4-5" drop in the back. I am not going to fill it just yet, I may have a radiator shop braze the neck back together.... any comments appreciated! Still have to finish up the fuel line, but for now it will just be tied into the original line under the cab with a filter in between.....
Also wanted to say thanks to members Rudy-G and 67Slider for the ideas and feedback...
$$ break down: Tank - Ebay $128 shipped 90 Ohm sending unit (same as our trucks) - Ebay $36 shipped Metal straps and angle iron - Home Depot $23 Flip down license plate bracket - Pick n Pull $7 New bumper and all hardware from LMC.... |
C/10 junkie
Nice write up, thank you.
looks great!!!!
#13 |
![]() Join Date: May 2002
Looks great, but one question. Is there a baffle or stop of some sort that keeps the gas from flowing out the back end on take-off? I have that same type of gas cap on the in-cab tank, but fuel still spills out when I turn to the right.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#14 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#15 |
Thanks for the detailed info. Looks great.
#16 |
Yet to be determined on this one, other guys have installed this same tank with no problems..... the cap is a non-vented one.... will make adjustments as needed though.
#17 |
Nice job. Looks great. Let us know how she fills.
Matt
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#18 |
![]() Join Date: Aug 2012
thanks for posting this, i'm going with this method after seeing how easy it is and i like having the cap behind the plate.
17 with a milling machine. 02 Sierra SLT Z71 ECSB lots of aftermarket 70 C-10 CST ECE 4/6 (building) |
#19 |
Is the tank resting on the cross sills or spaced?
#20 |
#21 |
old tank out of cab... been running fuel from the new tank 2 days... vent line needs to be re-worked... no fuel out the cap....
#22 |
No problems with filling the tank, no leaks out the cap. My son is driving it like this for a bit, so he can work on the back of the cab/front of bed at school....
#23 |
did you run that rubber hose as a gas line all the way?
#24 |
#25 |
![]() Join Date: Jan 2013
Has this been done to a SWB? Those wondering about fuel coming out, I have a 66 GTO, trust me I stomp on it, no fuel lose except what goes down the tri power!
