Old 02-04-2013, 10:39 PM   #1
6twenty5
6twenty5's Avatar
Need help!
I am trying to put the 70's tilt auto Van column into my 64. I have dissembled the original column to the point that the only thing left is the shaft. Which from what I can tell runs all the way to the rag joint. Am I supposed to cut the existing shaft and couple that to the new one?
I am lost. Any help will be greatly appreciated.
1964 Chevrolet C-10 SWB
Fort Worth, TX
6twenty5 is offline   Reply With Quote
Old 02-04-2013, 10:46 PM   #2
64shortbed
64shortbed's Avatar
Re: Need help!
You should be able to pull the whole column out in one piece. When i put my 80s jimmy tilt wheel in my 64 gmc i had to smooth up one side of the steering box shaft then it slide right on. Now idk for sure but id guess the 67-72 would go right on but i may be wrong.?? Mine is basicly the same as the 73 and up.
64shortbed is offline   Reply With Quote
Old 02-04-2013, 10:49 PM   #3
6twenty5
6twenty5's Avatar
Re: Need help!
Did your shaft run from the gear box all the way to the steering wheel?
Fort Worth, TX
Old 02-04-2013, 10:51 PM   #4
6twenty5
6twenty5's Avatar
Re: Need help!
The splined part of the new shaft has nowhere to attach to the old shaft.
Fort Worth, TX
Old 02-04-2013, 11:01 PM   #5
64shortbed
64shortbed's Avatar
Re: Need help!
I put in the whole tilt column. From the gear box rag joint to the wheel.
Old 02-04-2013, 11:02 PM   #6
64shortbed
64shortbed's Avatar
Re: Need help!
Not sure what your meaning there? Pics may help?
Old 02-04-2013, 11:21 PM   #7
6twenty5
6twenty5's Avatar
Re: Need help!
Here is a pic of the new column and the old shaft, I was told this was a 1970 Chevy van and from everything I read, it should bolt right in. You can see the obvious difference in shaft length.
Fort Worth, TX
Old 02-04-2013, 11:25 PM   #8
travz500
travz500's Avatar
Re: Need help!
The column bolts right in but your gonna need the shaft off the van and the rag joint or custom make the shaft to adapt to the newer column
travz500 is offline   Reply With Quote
Old 02-04-2013, 11:29 PM   #9
64shortbed
64shortbed's Avatar
Re: Need help!
Yep! Kind of missing some of it.
Old 02-04-2013, 11:40 PM   #10
travz500
travz500's Avatar
Re: Need help!
here is what you need to adapt it
Old 02-05-2013, 12:21 AM   #11
64shortbox
64shortbox's Avatar
Re: Need help!
There's a LOT more to it than than just shoving in a van tilt. You need to move the Neutral Safety Switch further down the column towards the firewall. You need to get an intermediate shaft from a newer truck. I used a special U joint to tie everything together. You will need to measure the od of the splined shaft on your van tilt and count the number of splines - I think it's a 3/4" shaft and 36 splines. I think most intermediate shafts are 3/4" DD .
Here's a great link with a fantastic write up and lots of pictures. I have an easier way of drilling for the Neutral Safety Switch tang. If you want more info just PM me for more info & pictures.
Here's the link:
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
64shortbox is offline   Reply With Quote
Old 02-05-2013, 12:21 AM   #12
6twenty5
6twenty5's Avatar
Re: Need help!
Thanks guys. I will see what I can do to get the rest of it. Or I'll just cut the old shaft and couple it.
Fort Worth, TX
Old 02-05-2013, 09:08 PM   #13
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Need help!
You don't want to do that really, you want that shaft to give a little, that's why the newer trucks have the two piece columns. I'd go get the intermediate shaft from a JY and be done with it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
