Old 02-05-2013, 01:24 AM   #1
WhippinSaw
WhippinSaw's Avatar
repro lower door skin patch
I'm about to install repro door bottoms and found this video of a 63 c10 door reskin on youtube.
WhippinSaw is offline   Reply With Quote
Old 02-05-2013, 01:39 AM   #2
198plus
198plus's Avatar
Re: repro lower door skin patch
He does some pretty nice work.
198plus is offline   Reply With Quote
Old 02-07-2013, 01:59 PM   #3
chillware
I'd like to see some pics of your progress...
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 02-07-2013, 08:01 PM   #4
WhippinSaw
WhippinSaw's Avatar
Just starting the patch job, (first take sheet metal repair for me) I'll take some pics. Watching boat's video helped alot.
Old 11-03-2013, 11:11 PM   #5
WhippinSaw
WhippinSaw's Avatar
I bought a Hobart handler 140 and I am happy with it. The passenger side fender closing panel was missing so the whole bottom of the door was rusted.
There was no door bottom left for a reference so I had to hang the door, get all the top and side clearances set, then measure 12 inches up from the rocker panel and add 1/4" for the bottom gap to find where the door bottom should be. There was also some repair needed to the hinge side of the door.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
Old 11-03-2013, 11:15 PM   #6
WhippinSaw
WhippinSaw's Avatar
Some rust holes around the door check, Easy to fill with a copper bar backing and got easier as I learned at what not to do.
Old 11-03-2013, 11:24 PM   #7
WhippinSaw
WhippinSaw's Avatar
This would of been a good candidate for a donor door so I thought I had nothing to lose. My drivers door had only the corners to replace and it was much easier as you maintain all the original door lines, only do this if you need the practice.
Old 11-03-2013, 11:28 PM   #8
WhippinSaw
WhippinSaw's Avatar
The inner door panel lines up everywhere except the corners where you need it. just get out the door skin hammer and massage it as needed.
Old 11-03-2013, 11:40 PM   #9
WhippinSaw
WhippinSaw's Avatar
The hinge side inner door panel was the same way and I had to work it a little. I went to fast welding the door skin on and ended up with a bump along the weld. Not to noticeable but I know its there. It was hard to fold over the door skin with a body hammer, then I found out you can run a DA gently down the edge to make it fold easier.
Old 11-03-2013, 11:50 PM   #10
WhippinSaw
WhippinSaw's Avatar
Painting and hanging. Gaps came out close and since its white you won't see warp on the door skin. Overall it was fun welding and the more you do it the better you get.
Old 11-04-2013, 12:18 AM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Wow!
Looks really good.
66 C20 Service Truck:
Old 11-04-2013, 08:36 AM   #12
Indian113
Indian113's Avatar
That sure looks nice, Good Job
Indian113 is offline   Reply With Quote
Old 11-04-2013, 09:08 AM   #13
bj383ss
bj383ss's Avatar
Nice Job. The black interior and white look great together. I've wondered what the stepside would look like with the Fleetside trim on the cab. Now I know.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 11-04-2013, 09:33 AM   #14
1963c-10
1963c-10's Avatar
Nice work....looks great
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-04-2013, 10:08 AM   #15
earl84
Really nice work. Like the black and white interior, too.
earl84 is offline   Reply With Quote
Old 11-04-2013, 11:40 PM   #16
Captainfab
60-66 Nut
Good job
Old 11-06-2013, 12:05 AM   #17
johnlq6975
Please post more on body work and rust repair that video was very helpful
johnlq6975 is offline   Reply With Quote
