02-05-2013, 02:21 AM | #1 |
4 speed transmission rebuild kit
hi guys i have a 1947 gmc advance design series truck and its a 4 speed transmission i was wondering where i would get a rebuild kit for the transmission thank you for any help
02-05-2013, 02:36 PM | #2 |
and a few others
Re: 4 speed transmission rebuild kit
You might try some of the vendors here:
http://67-72chevytrucks.com/vboard/s...d.php?t=392428 It's from the Pre-47 section, but many of them carry 47-59 parts.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
02-05-2013, 06:01 PM | #3 |
as many of those transmissions being removed from old trucks on this forum
you might be better off buying one from a board member they usually don't wear out or break what's wrong with yours?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-05-2013, 07:06 PM | #4 |
I'm with Orge, I have never broke or worn out an old granny 4 speed. Around here you can still pick them up for $100 or less (or the newer ones that will fit).
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-05-2013, 08:07 PM | #5 |
02-05-2013, 10:44 PM | #6 |
well i thought i would go threw the transmission and re do it but if i cant get a rebuild kit then
02-07-2013, 08:41 AM | #7 |
Hollister Road Co.
I agree with you taking it down and putting a bearing kit in it. 60yr old trans has to need it. The issue may be finding other parts for the 47 version of it. SM420 was around a long time but in 3 different versions. The popular ones are the 60's versions. Its a simple rebuild I'd go for it and you don't have to worry about it again.
02-06-2013, 12:55 AM | #8 |
The link that Arturo7 gave has what most people consider the whole rebuild kit for that trans. You don't replace the gears unless they are so worn or chewed up that they don't work good or unless they are broken.
02-06-2013, 02:43 PM | #9 |
you can get rebuild parts, but unless the trans you have has a problem i'd use it as is.
if it's leaking out the front or the rear, those seals are easy to replace without tearing into the trans. the only thing i've replaced on those old heavy duty trans are the rear seal and the speedo drive gear. i've pulled covers off those trans and have seen chunks broke off the sides of the gears from jamming a gear and they still work fine
02-06-2013, 06:13 PM | #10 | |
Look for Transtar on the web. Find the catalog section and look for the SM420. They have major kits minor kits, seals and gaskets, individual synchros, and anything else you might need.
02-07-2013, 12:48 AM | #11 |
Where is Lethbridge? I have the 4 speed out of my 53 Suburban I will make you a deal on if you're interested.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
02-08-2013, 03:10 AM | #12 |
Some of the bearings can be obtained from industrial bearing supply houses. It's possible some of the bushings can be obtained that way as well but I've never had to hunt them down outside of a bearing and seal kit.
02-08-2013, 11:24 AM | #13 |
i think i will just install a bearing kit and go from there maybe change the syncro's while im in there
02-16-2013, 01:53 AM | #14 |
I talked to the guys at the Novak site, Nice people and will help you. I was going to buy that kit to do mine. Unless I am doing something wrong...I think my synchros could use replacing. I try to double clutch even and still grind them. They also have a way of putting in a front seal so when you park downhill you don't leak oil. I haven't used them yet but think they might work. Never thought about seeing if someone here might have one they took out. I too have a 47 gmc and was keeping it pretty much stock.
02-16-2013, 09:21 AM | #15 |
Double clutching...now THERE's a lost art!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
02-16-2013, 01:47 PM | #16 |
And apparently I am not that good at it.
02-17-2013, 10:37 AM | #17 |
These folks had a full kit for my 3 speed saginaw That we rebuilt last year. Very helpful and guaranteed it was the correct kit. I think the girl at the desk is named Michelle. She really knows her stuff. Good luck.
Transmission Products Inc 490 W 2nd Street Tucson, AZ 85705 (520) 884-7134 |
02-17-2013, 11:38 AM | #18 |
Hollister Road Co.
02-17-2013, 06:02 PM | #19 |
06-17-2013, 09:38 AM | #20 |
Not really, I almost never hit the clutch brake. Sometimes I even give it a little throttle on the second push on the clutch{on an upshift}. The only time I use the clutch brake is to go from neutral into gear and if I get hung-up between gears when the splitter or selector act up.
06-17-2013, 09:05 AM | #21 |
Not around hereI'm an ex-log truck driver.
06-17-2013, 09:14 AM | #22 |
You got me there. I forgot about you professional guys!
06-17-2013, 09:17 AM | #23 |
Wish Cancer hadn't stopped that job
02-17-2013, 10:48 PM | #24 |
The input shaft can leak oil just driving and the seal conversion is pretty reasonably priced. You shouldn't be grinding gears unless you're trying to downshift into "granny" when coming into a stop. And making that shift happen is a challenge to say the least because there's a significant difference in gear ratio from Low to 1st. If you're not trying to crash through the gears and you're getting grinding, the synchros are probably bad. Hopefully the gears haven't suffered too badly. They're pretty tough, though.
02-17-2013, 11:00 PM | #25 | |
