Old 02-05-2013, 02:28 AM   #1
rcbildr
rcbildr's Avatar
60 GMC hydraulic clutch question
Question for those with the factory hydraulic clutch set up....whereabouts in the pedal travel does it feel like the clutch engages? I was told my truck has a new master (can't remember if the slave is new) and when I went to move the truck the engagement was at the very top of pedal travel. The truck has sat for a while with a leaky wheel cylinder (I recently replaced) so I'm thinking I just need to bleed it some more. Am I thinking along the right track? Thanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-05-2013, 03:06 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 60 GMC hydraulic clutch question
I no longer have the stock hydraulic setup, but perhaps these factory shop manual pages will prove helpful:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 02-05-2013, 10:27 AM   #3
Corts60
Just here to tinker
Corts60's Avatar
Grab two 9/16 wrenches, crawl under the pass side and adjust the rod that goes from the slave cylinder to the clutch fork. I can't remember which direction makes it higher or lower pedal travel but just play with it and you'll get it.
Old 02-05-2013, 03:01 PM   #4
LVPhotos
LVPhotos's Avatar
I run mine close to 1/4" from top. I can still quick shift.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
