Old 02-05-2013, 02:29 AM   #1
72chevynoob
Trailing arm mounts?
Anyone know where to find them? Im switching a 1980 axle into my truck, and Im wondering if any parts stores would carry them or if I have to order from cpp.
Thanks,
Justin
Justin
69 lwb project: http://67-72chevytrucks.com/vboard/s...d.php?t=558011
72chevynoob is offline   Reply With Quote
Old 02-05-2013, 09:34 AM   #2
SCOTI
SCOTI's Avatar
Re: Trailing arm mounts?
Not available @ local auto parts places. Try one of these....
CPP
Early Classic Enterprises
Porterbuilt (board vendor)
Stock Car Products (Carl's)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-05-2013, 12:00 PM   #3
Pro Performance
Pro Performance's Avatar
Porterbuilt does have them.
- Travis
Pro Performance is offline   Reply With Quote
Old 02-05-2013, 12:49 PM   #4
72chevynoob
- Travis
How much are they? Shipped will be more, I know.
Justin
Old 02-05-2013, 01:06 PM   #5
Pro Performance
I want to say $50 + $20.... but I could be wrong, as they usually come in there 73-87 trailing arm kit. Give Dave a call over there @ 480-297-2621, and he will get you all setup. That is the only place I know that has them, not to say there couldn't be others though.
Old 02-05-2013, 02:34 PM   #6
72chevynoob
I did find them on the cpp website, but I would like to look at my options. If anyone was wondering they are $39 from cpp.
i]Posted via Mobile Device[/i]
Justin
Old 02-05-2013, 02:55 PM   #7
project 67 sub
project 67 sub's Avatar
You could always carefully cut them off of your existing axle....
project 67 sub is offline   Reply With Quote
Old 02-05-2013, 03:00 PM   #8
Pro Performance
The trailing arm mounts are angled on the axle, where as the leaf springs mounts are straight.
Old 02-05-2013, 03:02 PM   #9
72chevynoob
I have both axles, but I think once I cut it off it would be wrecked.
Justin
Old 02-05-2013, 03:18 PM   #10
Pro Performance
Oh... then what project 67 sub mentioned might work. I have never done it, but it seems like it might be an option if you were to carefully do it. Guess it depends on what you use to cut them off also.
Old 02-05-2013, 09:33 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Early Classic Enterprises sells them for 39 dollars also. Top notch folks to deal with.
And you don't have to deal with CPP. Read the review board. We should rename it the 'CPP complaint board".
Old 02-06-2013, 12:44 AM   #12
72chevynoob
I went to order them from ECE, but the shipping quote was $100 with some sway bar mounts too. On that note, how would you guys suggest cutting the old ones off?
Justin
Old 02-06-2013, 12:55 AM   #13
trevrolet65
I would see how a small air grinder would fit, maybe try differant cutting wheels. Slowly cut the welds, not the axle and not the mount. Actually, I would get my angle grinder, because I'm fairly accurate with it, grind the welds thin, then knock'em off with a welding hammer.
trevrolet65 is offline   Reply With Quote
Old 02-06-2013, 01:08 AM   #14
72chevynoob
Thats what I was thinking. Just hope the original welds didnt have very good penetration. Im pretty good with an angle grinder too. Actually its the only cutting tool I use.
Justin
Old 02-06-2013, 01:23 AM   #15
trevrolet65
Can't you roll the carrier and axles out of the doner truck into the older axles and put in new races while you have it apart?
Old 02-06-2013, 01:51 AM   #16
72chevynoob
I wish. This one is 1.5" wider, and is 5 lug. Im keeping the gears from the old axle though.
Justin
Old 02-06-2013, 07:49 AM   #17
Tx Firefighter
Man, you got to call them or something. I've ordered a bunch of full 4/6 drop kits from them (spindles, four shocks, four coil springs, track bar, shock mounts) and the shipping for all of that was only 50 bucks for all of it and that was several boxes totaling probably 100 pounds. I can't imagine 100 dollars shipping for a pair of saddles and sway bar mounts.
EDIT: I just looked and realized you're from Canuckistan. Maybe I'm barking up the wrong tree with my shipping info.
Old 02-06-2013, 09:25 AM   #18
SCOTI
SCOTI's Avatar
Is there a reason the truck arm housing needs to be kept in tact after removal of the mounts on this particular rear end? If not, cut the mounts off the rear housing completely (cut the housing apart & remove the areas the pads sit on). Then, slowly grind, cut, trim the housing material away from the pads.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2013, 01:59 PM   #19
72chevynoob
I was planning on reselling axle to cover some costs.
Justin
Old 02-06-2013, 03:40 PM   #20
project 67 sub
use a plasma cutter to cut them off
Old 02-06-2013, 04:07 PM   #21
SCOTI
SCOTI's Avatar
If one has a plasma cutter.... one doesn't need the recommendation to use it typically . I'm betting he doesn't have one @ his disposal.
Not sure what you can get for a truck arm 12-bolt w/o the pads. Call ECE or Porterbuilt & speak to someone & confirm prices/shipping.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2013, 04:31 PM   #22
project 67 sub
true lol. but he could take it somewhere that has one and get them to cut them off, it may be cheaper and quicker than buying and having a new set shipped
Old 02-06-2013, 09:21 PM   #23
72chevynoob
Double post
Justin
Old 02-06-2013, 09:22 PM   #24
72chevynoob
I called ECE. 39 bucks for the pads, 26 for shipping, and 10 for brokerage and taxes. So 75 total. Seems like a lot for two little pieces of steel. I will still contact nate, but I dont imagine pricing will be much different.
Justin
Justin
Old 02-07-2013, 11:50 PM   #25
AustinScott
AustinScott's Avatar
Another option...... Comes with seals
http://www.performanceonline.com/1960-72-CHEVY-C10-C20/
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline   Reply With Quote
