Old 02-05-2013, 09:34 AM   #1
chadcampbell00
chadcampbell00's Avatar
Proportioning valves
I bought a '70 Jimmy a few weeks ago and the rear breaks have a tendency to lock up at more sudden than normal breaking. It's pretty bad on gravel and causes the rear end to slide sideways. The previous owner installed all new braking components (booster, master cylinder, drums, shoes and the rubber lines). It has drum brakes front and rear. I noticed that it has a proportioning valve but I thought only vehicles with front disk brakes had that. I'm not real familiar with proportioning valves so if anyone is I could use some advise. Did these models come factory with them or was it added? Should I replace it or bypass it? I have seen some adjustable ones online, should I try one of those? Or maybe my problem has nothing to do with that. Both rear wheels lock up so I don't think it's a cylinder problem and they should be self adjusting. They release when I let off the brake so I don't think they are too tight anyways. Any advise?
chadcampbell00 is offline   Reply With Quote
Old 02-05-2013, 07:17 PM   #2
cleszkie
cleszkie's Avatar
Re: Proportioning valves
Before you go bypassing or replacing things, check that the rear brake shoes were installed properly. Each pair of shoes has one with a shorter length of brake lining and one with a longer length of brake lining. If my memory serves me, the shoe with the longer brake lining should be installed in the forward position on the backing plate. If this is reversed, the drum brakes can have a tendency to lock up. If I have this backwards, hopefully someone here will correct me. I swapped in disc brakes on the rear a while back, and have let all my drum brake knowledge dwindle.
cleszkie is offline   Reply With Quote
Old 02-05-2013, 09:46 PM   #3
pound41
it had a prop valve on it when it came from factory. I don't think it had a bleeder on it. I would look at adjustments on the drums etc before I start swapping out valves
pound41 is offline   Reply With Quote
Old 02-05-2013, 10:15 PM   #4
chadcampbell00
Thanks. I had my tires balanced the other day and while they had them off I took the brake drums off just to take a quick look. They both came off with ease so I don't think that they need adjusting but I'm gonna double check that anyways. I will also take them back off and make sure the shoes are on correctly.
