Old 02-05-2013, 03:54 PM   #1
99monte
77 chev 02 gm diff compatability
I will be resurrecting a 77 chev 10 in the spring,but am currently stripping an 02 gmc 1500.The rear diff in the 02 (3.42,posi,disc brakes,6 bolt) is crying out to me to be used.Has anyone done a swap like this? My first concern is the wheel bolt pattern,I want to keep the factory rims.Is there an axle that will fit in this housing with a 5 bolt pattern,or do I need to get these axles (and rotors) drilled for a 5 bolt?I haven't looked into any other compatability issues I may encounter,Any thoughts?Name:  IMG_5139.jpg
99monte is offline   Reply With Quote
Old 02-05-2013, 04:35 PM   #2
MalibuSSwagon
Re: 77 chev 02 gm diff compatability
Another issue you may run into besides the lug pattern, is the width. The late models use fairly high offset wheels, while the C10 uses a 0 offset wheel.
MalibuSSwagon is offline   Reply With Quote
Old 02-06-2013, 07:29 PM   #3
Duster
Duster's Avatar
That 10-12 bolt in the 77 will be way stronger than that new axel. Yank it out and sell it on craigs list, take the money and rebuild the origional axel. Then swap that LS motor into the 77.
Duster is offline   Reply With Quote
Old 02-07-2013, 12:56 AM   #4
andrewmp6
Like said sell the rear end and put the cash in your truck.
andrewmp6 is offline   Reply With Quote
Old 02-07-2013, 03:45 PM   #5
99monte
I have the diff advertised for sale,hope it goes soon,I'd like the space back in my shop.The LS has another destination
Old 02-09-2013, 06:52 PM   #6
bdiamond
I want to swap the late model disc brakes on to my 12 bolt. Not sure if it'll work or not.
bdiamond is offline   Reply With Quote
Old 02-10-2013, 09:29 AM   #7
andrewmp6
Check the backing plate bolt patterns see if they are close or not.
Old 02-10-2013, 12:23 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
They won't "bolt on". If you want rear discs on a budget check our Vendor Marketplace.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
