Old 02-05-2013, 09:20 PM   #1
HugoV
Another drum to disc question... sorry!
Hi guys and gals!
I did some research but could not find the exact answer I was looking for, so help!
My 64 c10 frame is done being media blasted and painted, so here comes the fun part, reassembly!
I am going with a drum to disc conversion.
My question is which supplier should I go with for the complete kit?
bowtiebits.com - $599.00
http://www.BowtieBits.com/store/stor...Category_ID=84
CPP - $799.00
http://www.classicperform.com/Store/...6062SWBK-5.htm
earlyclassic.com - $759.00
http://www.earlyclassic.com/catalog....version%20Kits
Or what kit have you guys used?? I am also planning on doing new ball joints etc, so if there is a kit that comes with all of that it would be great!
Thanks for the advice!
fyi - I rather pay for the convenience of buying a kit, VS buying each part individually. (unless it's going to save me money!!)
If i go with 5 lug disc up front, where should I get the rear end from? keeping in mind that I want a cruiser so gas mileage is also key for gear ratio...
HugoV is offline   Reply With Quote
Old 02-05-2013, 10:23 PM   #2
luvbowties
luvbowties's Avatar
Thumbs up Re: Another drum to disc question... sorry!
I cannot answer, as I always got parts from donor vehicles--cheaper for me around here.
Also, CAUTION: It'd be a good idea if you checked vendors' reputations and caveats (?some where?) in this forum. Some members have had bad experiences....what a shame, really. Would be nice to not have to do that!!!
Sam
luvbowties is offline   Reply With Quote
Old 02-05-2013, 10:27 PM   #3
Lugnutz65
Lugnutz65's Avatar
Explore this Vendor Review Section from this forum.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 02-05-2013, 10:27 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: Another drum to disc question... sorry!
Originally Posted by HugoV View Post
Hi guys and gals!
CPP - $799.00
If your present diff'l & ratio are ok, either order replacement 5-lug axles OR, second best, pull your axles and have them re-drilled for the 5-on-5 inch bolt pattern. Depending on local machinists, re-drilling might save a few $$$.
HTH,
Sam
