02-05-2013, 11:14 PM | #1 |
Front Brake Hose Interference
I just finished installing a ECE lowering kit on my 1977 Stepside. I went to reinstall the front brake hoses and found that they rub the bottom of the upper ball joint stud. I'll have to tweak the hard line piece that attaches to the caliper to get the hose away from the stud. Anybody run into this issue and if so, what was your fix? Thanks, Jim M
02-05-2013, 11:16 PM | #2 |
67-72 parts collector,…
Re: Front Brake Hose Interference
Very common problem.
Just tweak the hose. No big deal. Posted via Mobile Device
02-05-2013, 11:18 PM | #3 |
GoatLube Experss
X2, on every truck I put drop spindle's on. just a minor tweek and it's good.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
