Old 02-05-2013, 11:56 PM   #1
1967chevytruckguy
how to remove cab from frame ?
can someone tell me how remove the cab from my frame send pics if possible ?
1967chevytruckguy is offline   Reply With Quote
Old 02-05-2013, 11:59 PM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: how to remove cab from frame ?
Make sure all your wires and tubes are disconnected along with steering column ect then the 4 cab mount bolts
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 02-06-2013, 12:03 AM   #3
1967chevytruckguy
so just rip all the wiring out or it will come right out with it
Old 02-06-2013, 12:05 AM   #4
Scott>72-GMC
Unplug everything unless u plan on replacing all the wiring. Cut away if u wish to go that route
Old 02-06-2013, 12:10 AM   #5
70blackfish
I saw a post awhile back, guys were using cherry pickers with a 4x6 on top and lifting in up from the inside, can do by yourself.
I need to do the same thing
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 02-06-2013, 12:34 AM   #6
Scott>72-GMC
Yes I've seen a vid ill see if I can find it
Old 02-06-2013, 12:52 AM   #7
Scott>72-GMC
Basically it's as seen here BUT some supports aren't seen. You want two boards going across the cab door to door if you don't and just use the board only seen in this pic you can distort the cab
