Old 02-06-2013, 03:09 AM   #1
jcd9730
jcd9730's Avatar
Electric choke?
I have a 4barrel quadrajet, Im not sure the exact model, but it does not have a choke at all. I want to put an electric one on, but any kind of kit I have found is for Holleys, edlebrocks, not quads. Do yall know of anywhere i can find a kit, and is there anything else I would need to get/know when installing a new choke?
jcd9730 is offline   Reply With Quote
Old 02-06-2013, 10:14 AM   #2
Lee H
Lee H's Avatar
Re: Electric choke?
Can you be a little more specific with this statement? Does it have the choke butterfly, choke housing, linkage? If not you'll need to find a carb to gather parts from. If yes then Edelbrock part number EDL-1932 is a kit to change your Q-Jet to an electric choke.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-06-2013, 11:01 AM   #3
geezer#99
geezer#99's Avatar
Re: Electric choke?
Pic of your carb would help!!
Old 02-06-2013, 11:39 AM   #4
jcd9730
jcd9730's Avatar
Re: Electric choke?
It has nothing at all. Just the small screw that would go the the fast idle cam I believe? No linkages, nothing. I dont have the truck right now, so I cant take pictures, sorry.
Old 02-06-2013, 01:23 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Electric choke?
You probably have the divorced choke with the spring and heat stove in the intake manifold. Also you probably don't have the vacuum choke pull offs. My advice would be to set up a manual choke or buy an edelbrock with the electric choke set up on it.
I'd also make a signature with my truck details in it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-06-2013, 01:57 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Electric choke?
Here's a couple of pics of the divorced choke.
Name:  Q-Jet choke linkage.jpg
Name:  Q-jet choke rod.jpg
VetteVet
Old 02-13-2013, 04:10 AM   #7
jcd9730
jcd9730's Avatar
Re: Electric choke?
So the picture is what the passenger side looks like right now. Evidently when the PO rebuilt this, the inlet where the fuel line attaches was stripped, so the whole base was replaced. So there is nothing in the way of a choke anymore. He didnt care, but these cold starts are getting to be a pain.
This is what I was thinking of installing-
http://www.summitracing.com/parts/jet-201355
I just dont see how to attach it, or where the thermostat will attach?
Will this work? And how would I set this up? Or am I better off just finding a manual choke kit?
Old 02-13-2013, 10:01 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: Electric choke?
Pic doesn't show whether you have a choke butterfly on top.
As Lee H mentioned your best bet is to find a carb at a salvage yard or on Ebay to take parts from. I see some on Ebay and Craigs for sale for parts only pretty cheap.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-13-2013, 10:09 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: Electric choke?
Pic of my M4MC which is almost identical to yours:
06 Trailblazer
Old 02-13-2013, 11:11 AM   #10
jcd9730
jcd9730's Avatar
Re: Electric choke?
Ok I guess Ill find a salvage one then. Thanks for the help!
Old 02-13-2013, 11:24 AM   #11
jcd9730
jcd9730's Avatar
Re: Electric choke?
Also, do I need a choke pull off with an electric choke? Sorry, I still am learning about chokes, and Im not really sure what the pull off is for.
Old 02-13-2013, 11:37 AM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Electric choke?
From what I gather you have a mismatch of carburetor and intake with missing parts on both. The carburetor is not designed for the kit from summit. It is designed for the divorced choke setup in the pictures I posted . The choke spring is mounted in the intake in a horizontal chamber and the linkage rod comes straight up from that to the choke linkage on the carb, which is missing on your carb. See my pics above.
Here is another one.
Here is a kit from Edelbrock I found on EBay
Your intake is made for a thermostat coil and it comes out of a slanted chamber and goes to a linkage on the side of the carb which you don't have and is similar to the above type. It is slightly different from the top picture. Notice the wire on the bottom of the picture with the screw. It is a manual choke wire.
The newer style has a heat tube which I believe comes off of the exhaust manifold to a black coil, It resembles the electric choke on the newer carbs.
The kit you saw from Summit is made to replace it and it uses electric current to heat the spring and release the choke. You drill out the rivets and pull the spring out then install the electric kit with the screws then hook up the linkage and wire it to 12 volts key on source.
This picture shows it and the red cap is where the heat tube would connect if you had one.
The easiest solution would be a manual choke kit if the vehicle runs great. If not then I would just find a carb with the electric choke and change it out.
VetteVet
Old 02-13-2013, 11:44 AM   #13
68gmsee
Active Member
68gmsee's Avatar
Re: Electric choke?
Here's a youtube video of how it works. It allows air intake when engine starts to keep engine from running too rich. Once engine warms up, the choke will keep the choke butterflies open all the way.
06 Trailblazer
Old 02-13-2013, 05:15 PM   #14
jcd9730
jcd9730's Avatar
Re: Electric choke?
Well that certainly cleared up alot! Thanks guys!
