Old 02-06-2013, 09:53 AM   #1
mccurrkm
mccurrkm's Avatar
Lokar shifter too short?
Let me recap a little info first. I bought an 86 c10 with the 6.0 4l80e already installed and running...I stripped it all and put it in my truck. They had the motor in wrong with the adapter plates on the wrong sides of the truck so they moved the motor mounts back instead of finding the problem. Now that I have it correctly mounted in my truck, I ran into a problem with the shift linkage yesterday. I have the Lokar shift linkage that they had in the truck. It was hooked up in that truck but now in mine, it is too short and appear to be running right through where the exhaust will be going to the headers.
I am running the Dough Thorley headers and it is a 6.0 4l80e. My questions is...what do I need to do? I don't know if they shortened the rod on the linkage or if it even came with the rod to begin with from Lokar. I don't have a close picture of the linkage but I can try to get one later....there are current pictures on my build thread on page 3 if that helps. What are you guys using? I'm just a little confused here. Thanks!
My 85 LQ4 Build
mccurrkm is offline   Reply With Quote
Old 02-06-2013, 09:56 AM   #2
mccurrkm
mccurrkm's Avatar
Re: Lokar shifter too short?
Here is a picture where you can somewhat see it...it is just hanging down here though.
My 85 LQ4 Build
Old 02-06-2013, 10:30 AM   #3
cdowns
cdowns's Avatar
i've found that when i have a linkage that is too short it is easy to FABRICATE a longer one
Old 02-06-2013, 10:48 AM   #4
mccurrkm
mccurrkm's Avatar
Ooi
Haha yea it shouldn't be too hard, I'm just trying to figure out why I am having there issues. Hoping it isn't that I did something else wrong
My 85 LQ4 Build
Old 02-06-2013, 11:40 AM   #5
ls1nova71
ls1nova71's Avatar
Maybe they put the engine in the spot they did so the linkage would clear the exhaust?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
