Old 02-06-2013, 07:40 PM   #1
jorgensensc
jorgensensc's Avatar
Power window switch. What are y'all using?
Hey guys. Need a brain break from the engine swap dilemma. So I'm going to order the power windows for the 'burb. I'm having some difficulty figuring out which switches to use. I have the '72 door panels with the raised area on the window crank area (long regulator). I would like to use the regular chrome up and down switches (standard GM style). What I can't figure out is if it will cover the hole if I cut off that raised area and place them in that spot. Has anyone done it that way? I know I can use the window crank switches, and while that looks super stock, I can't justify 120.00 each for switches. Any help or advice would be appreciated.
Thanks!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-07-2013, 03:02 AM   #2
jorgensensc
Re: Power window switch. What are y'all using?
I know someone has to be running power windows with a stock interior, right?
Old 02-07-2013, 07:43 AM   #3
Steve Hafner
Steve Hafner's Avatar
Here's the only picture I've saved of a power window switch.
It's a '72 Chevy 400 . . . looks like it could have come that way from the factory.
Steve Hafner is offline   Reply With Quote
Old 02-07-2013, 01:57 PM   #4
jorgensensc
THat one looks Good! Unfortunately I can't do the wood on the overlays suburban dor panels. The rear door ones would be very difficult to make.
