02-06-2013, 08:40 PM | #1 |
I need help.
I have a 71 blazer and have replaced the floor pans kickers and the rocker panels. I have hung the doors back on to check the gaps. I found my passenger seat with a little bit of work lines up perfect. As for the driver side there's a 5/8 gap on the top of the door and a 1/4 inch gap on the bottom. I do not have the roof on and tried every which way with the hinges to adjust the gap but to no avail. I have the old hinges on the truck. Any help would be appreciated.
Posted via Mobile Device |
02-06-2013, 08:55 PM | #2 |
oldschoolblazer@yahoo.com
Re: I need help.
My understanding is that on our Blazers
Because they have the body attached you must start By adjusting the back of the door first. I have seen worn out or even different size Body mounts make a big gap like that. Posted via Mobile Device |
02-09-2013, 04:30 PM | #3 |
Re: I need help.
I ordered in the body mounts ant the doors and rockers fit perfectly thanks a ton man.
Tags |
door floor alignment |
