"Ochre Ogre"
Is there a correct propeller shaft alignment?
I would assume that there is a right and wrong alignment on the front drive shaft. Looking at the constant velocity U-joint, if the front yoke on the drive shaft is horizontal, I am thinking that the other end at the slip shaft should be horizontal also. I looked under my other 4x4's and 2 were 90 degrees off and one was as I described. What say the experienced 4x4 gurus. (or doesn't it matter at all)
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
On a shaft with a double cardan joint at the t-case, it does not matter what the orientation of the other end (u-joint at axle) is.
Tim |
user # 2756
![]() Join Date: Jun 2001
What Tim said. Also the angle at the u-joint end should be as close as possible to zero degrees.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
"Ochre Ogre"
Thanks!
"Ochre Ogre"
Ok, now inside this double cardon joint is a spring. What is it's purpose? Because it sure doesn't look like it does much of anything.........
