Old 02-06-2013, 10:14 PM   #1
W.I.P.72
W.I.P.72's Avatar
Need Brake Info!!!
Hey everyone, I am looking to get the CCP disc conversion kit form 69 and i was wondering if anyone has used this kit before.
http://www.classicperform.com/Store/.../6366cbk-6.htm
If so, is everything that you need included, will i need any special tools, and does anyone already have a install guide. If not I will order the kit and figure it all out and make a thread.
Thanks everyone.
OKLAHOMA MEMBER MEET JUNE 15, MIDWEST CITY OK.http://67-72chevytrucks.com/vboard/s...d.php?t=559886
72 C-20 Stepside - Work In Progress
W.I.P.72 is offline   Reply With Quote
Old 02-07-2013, 12:42 AM   #2
andrewmp6
Re: Need Brake Info!!!
It shouldn't be hard the front the biggest part is taking out your old spindle.The rear you will have to pull out both axles so while you got the diff cover off look at your gears and change the gear oil.
andrewmp6 is offline   Reply With Quote
Old 02-07-2013, 12:58 AM   #3
W.I.P.72
W.I.P.72's Avatar
speaking of gears, how do i tell what i have?
Old 02-07-2013, 01:10 AM   #4
andrewmp6
I didn't want to copy paste all this but http://www.how-to-build-hotrods.com/gear-ratio.html
Old 02-07-2013, 07:56 PM   #5
W.I.P.72
W.I.P.72's Avatar
wow i knew this and totally forgot.... thanks for the link...
Old 02-08-2013, 03:12 AM   #6
andrewmp6
Don't feel bad i knew it just didn't know the math off the top of my head.
Old 02-08-2013, 07:48 PM   #7
W.I.P.72
W.I.P.72's Avatar
looks like i have 3.70 or 3.73, i need more top end, i think i need to change the tranny, 3 on the tree. on the high way all i can really go is about 60-65 and that is at really high rpms...
Old 02-09-2013, 03:50 AM   #8
andrewmp6
I would look in to a over drive trans like a 700r4 unless you want to keep it a stick.A t5 from a 3rd gen f body is cheap a over drive its good tell about 350-400hp tho.
