Old 02-06-2013, 11:55 PM   #1
solidaxel
solidaxel's Avatar
Dirty Dingo Serp. Belt Routing
Can someone please send me a pic of the belt routing on a 2006 5.3 with a raised Dirty Dingo A/C bracket and idler, stock alternator and power steering pump and the part number of the belt, or total inches of belt
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-09-2013, 09:46 PM   #2
solidaxel
solidaxel's Avatar
Re: Dirty Dingo Serp. Belt Routing
Anybody with a pic of a 5.3 and DD A/C bracket !!!!
LS 3 4L70E
Old 02-09-2013, 09:53 PM   #3
69trk
69trk's Avatar
Might go to dirty dingos' site. If i remember right they have picts.. I'm planning on running a ac bracket from lsbrackets that moves it up and inward so i can fit some forward facing headers..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 02-09-2013, 10:19 PM   #4
solidaxel
solidaxel's Avatar
You are right but he only shows his bracket and not the rest of the pulleys and acc.
LS 3 4L70E
Old 02-10-2013, 10:39 AM   #5
85burb
85burb's Avatar
From there web page it goes from ac to under water pump. Kinda crappy instructions. From under water pump I have no ideas.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-10-2013, 11:34 AM   #6
gumbys10
First picture looks close. Remove the belt from the idler between the altenator and power steering pump, allow it to go straight there, and route the belt under idler pulley between the a/c compressor and altenator and you will have it routed correctly.
gumbys10 is offline   Reply With Quote
Old 02-10-2013, 12:22 PM   #7
solidaxel
solidaxel's Avatar
Thanks,
I went back and found the pic you have shown and it is for one of his PS and Alt brackets,
I am only using the DD A/C upper mount bracket, and adj. motor mounts.
I am going to get a hand full of different length belts and re route the belts until everything works.
I think I am the only one to use one of these A/C brackets on this site !!!
LS 3 4L70E
Old 02-10-2013, 07:18 PM   #8
gumbys10
I have one, I just have not installed it yet lol.
Old 02-10-2013, 07:39 PM   #9
mooseknuckles
mooseknuckles's Avatar
think it goes this way.....cause of the throttle body....
mooseknuckles is offline   Reply With Quote
Old 02-10-2013, 07:48 PM   #10
solidaxel
solidaxel's Avatar
Thanks,
I am going to measure for a belt the way you have it shown.
That way also clears the water outlet and intake
LS 3 4L70E
Old 02-10-2013, 10:45 PM   #11
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I have to say...I certainly like that setup better then the kwik one
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-13-2013, 11:33 PM   #12
solidaxel
solidaxel's Avatar
Here is the final results after 6 tries, and the same amount of trips to the parts store !!
I think the belt could have been the next 1/2 size smaller, but I think I will ware this one out then see.
Thanks to all for the help and pics,
now on to the sencers and wiring, and fuel lines
LS 3 4L70E
