Old 02-07-2013, 12:54 AM   #1
The German
The German's Avatar
Engine Question...GenI or GenII !?
Hi guys!
I would order at summit an edelbrock or trick flow cylinder head combo.
I ve crate engine in my 1970 truck!
The engine no is: 10066036 !
Is this gen I or gen II!?
I dont want to order the wrong heads...because its a big problem to change them,because i life in germany.
Regards
Sascha
The German is offline   Reply With Quote
Old 02-07-2013, 01:39 AM   #2
airdale94
airdale94's Avatar
Re: Engine Question...GenI or GenII !?
From the numbers it looks to be a Gen 1 Targetmaster. Gen 1's are anything up until 1987. Gen 1's use a 2 piece rear main seal. Whers as Gen 2's use a 1 piece that has a removable rear housing. A external oil seal. Where as the 2 piece is internal mounted in the crankshaft's rear main bearing cap.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 02-07-2013, 09:58 AM   #3
The German
The German's Avatar
I found this about my engine:
Engine: gm target master 350cui
Transmission: th350
EXISTING CAM SECTION
Cam Brand: GM
Valve Lift Intake and Exhaust: .383 - .401
Duration at .050: 194/202
Lobe Separation: 112
Camshaft/Lifter Type: Hydraulic Flat
Computer Controlled: No
Emissions Legal: No
ENGINE SECTION
Connecting Rod: GM # 10108688
PISTON SECTION
Piston Brand: GM # 12514101
Piston Material: Cast
Compression Ratio: unknown
Piston Type: Flat
CYLINDER HEAD SECTION
Cylinder Head Brand: GM casting # 334417369 similar to old #882
Cylinder Head Material: Cast Iron
Combustion Chamber Volume (CCs): 76
O-Ring Groove: No
Intake Valve Size: 1.94
Exhaust Valve Size: 1.50
Port/Polish: no
CRANK SECTION
Crank Brand: GM # 3932444
Crank Type: Cast
RODS SECTION
Rod Brand: GM # 10108688
Type: Cast,
Length: ,
PUSH ROD SECTION
Diameter: ,
FORCED INDUCTION SECTION
Regards
Sascha
