![]() Join Date: May 2005
Satisfaction with the LS swaps????
You guys that have made the swap into the Blazers, How are the results? I finally worked out from under an LT1 I had started and have picked up a low mileage 5.3. Plan on DBC, aftermarket harness, stock manifolds and using the factory mout compressor.
#2 | |
Re: Satisfaction with the LS swaps????
Good luck with the swap!!
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399 |
Love mine, used a 6.0 and a 4L60E behind it. 3.73's with 33" tires and a custom SD tune. I get 22 mpg highway and 17 mpg city. Ran 14.40's at 95 mph. Plenty of power for a high centered 4x4
got the 5.3 (I hope) to the house, will check the crank this week end.... looking to keep it simple.
![]() Join Date: Jan 2007
Very happy here. However, I get nowhere near what FirebirdJones gets.... the last I checked I get 11mpg on average. But, that's with 4" lift, 35" tires and no top... I do have a bit of a heavy foot because it sounds and feels so good.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
#6 | |
How do you like your 8.1? I'm looking at buying a suburban (03-06 model) 3/4 ton with the 8.1 if I can find one with decent miles on it. I run a GM crate 502 in my 79 1 ton pickup, love the grunt. |
Yes, I'm referring to the K5...but I haven't checked my mileage in a year or so. Maybe its better.
![]() The 8.1 is not yet running. My other two trucks are driveable. I'm getting close on the 8.1, though....
Checked the crank, a 5.3. Oil Pan area looked great........ Now to get the UPS guy busy
I'm late to this thread but what about the stock '72 transfer case. How did you fit it into the 4L60E?
Posted via Mobile Device |
I am keeping the 700r4 I had just put in it when the 350 went down...... maybe one of the other guys will chime in......
Ordering stuff this week, next week in Destin then time to go to work.... |
Thanks JMac!! I'll be watching the thread.
#13 |
That's awesome!!! Thanks!
