Old 02-07-2013, 04:25 PM   #1
LuckyJoe
LuckyJoe's Avatar
How Should I Raise This Truck?
Guys, This truck has to come up. I can't even get it into my local Kwik-Car for an oil change since it is so low. This truck is new to me and has the fliped rear end / with a front Camero Clip. Now the question is how best to raise it. In the front I would assume I could just install new coils, since they were cut, how much is unknown, ( no dropped spindles ). In the rear, I was thinking I could undo the flip and go back to stock and then do blocks if needed. I would like to bring it up 2" front and 3" or so in the rear. At the rear bed step it is 7.5" at the bottom to the floor. I talked with a local shop and they said just re-arch the rear springs. Wouldn't the re-arch move the mounting points inward on the flat plane. Help, I stupid on this subject.
Joe,
LuckyJoe is offline   Reply With Quote
Old 02-07-2013, 04:33 PM   #2
Tshort1
Tshort1's Avatar
Re: How Should I Raise This Truck?
I vote leave it the way it is, it looks Awesome and do your own oil changes.
Tshort1 is offline   Reply With Quote
Old 02-07-2013, 04:40 PM   #3
JNJchev77
Registered Cruiser
JNJchev77's Avatar
X2
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 02-07-2013, 05:22 PM   #4
canadian trucker
A day should have 30 hours.
Welcome to the forum
Truck looks great the way it is.
Got anymore pictures?
canadian trucker is offline   Reply With Quote
Old 02-07-2013, 05:41 PM   #5
LuckyJoe
LuckyJoe's Avatar
I guess I could do my own oil changes....Just haven't done that in years, even with all of my past hotrods. Maybe I need to make some personal changes in regards to this. The truck actually rides and drives real well. I know.... Pics...I got pics, just in the garage though. Haven't had too much time to get out....just been going over this and fixin problems along the way. I'll get more pics later when it warms up a bit. Shes running a Ram-Jet 350 / 700R-4, 10 bolt posi 373 and leaves two real nice strips when needed.
Joe,
Old 02-07-2013, 06:42 PM   #6
JNJchev77
Registered Cruiser
JNJchev77's Avatar
A Porterbuilt Dropmember & 4link would take that thing to the next level!! Beautiful truck Joe!
77' Chevy SB
5.3/4l60e combo
Old 02-07-2013, 06:46 PM   #7
see ten
WTB this ad
see ten's Avatar
Putting the rear axle below the spring will make a block useless... unless you want it taller... that's how the 4x4 guys who don't want to buy new springs lift their trucks.
see ten is offline   Reply With Quote
Old 02-07-2013, 11:06 PM   #8
Reyals Bemus
Leave it alone!! It looks great as is.
Reyals Bemus is offline   Reply With Quote
Old 02-08-2013, 03:06 AM   #9
andrewmp6
Yeah i would do my own oil changes i use to work at a garage and seen a few mess up a oil change before.Some forgot to chain the oil filter one he always left the plug out of the oil pan lol.Your idea to raise it up will work but most of us will tell you to air bag it tho.The front would be bolt in the rear will take some welding to bag.
andrewmp6 is offline   Reply With Quote
Old 02-08-2013, 12:31 PM   #10
Ziegelsteinfaust
Get a 2x8, and cut it down so you can use it as a quick ramps at the oil change places.
I have a 70 Nova That had almost a 4-4 drop, and I had to make ramps just to get a low profile jack underneath it.
I found 2 inches was usually enough for most situations, and if you need you could double stack the ends.
Ziegelsteinfaust is online now   Reply With Quote
Old 02-08-2013, 04:57 PM   #11
LEEVON
Moderator
LEEVON's Avatar
I think it's just right! I have to jack up a framrail just to get a low profile jack under my crossmember. Forget trailering or the oil change place...
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-08-2013, 05:18 PM   #12
msgross
msgross's Avatar
airbags to raise and lower?
nice truck though and welcome to the board...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-08-2013, 05:48 PM   #13
SCOTI
SCOTI's Avatar
Excellent advice. I don't do my own oil changes usually because it's easier to let a shop do it & dispose/recycle the oil @ the same time. I do hate all the BS they try & add to the ticket but if you find the right shop (usually a smaller/older place) they'll do only what you ask & not try to up-sell.
Super nice truck!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
