02-07-2013, 05:00 PM | #1 |
Major swap in my future
This weekend I am taking delivery of a 1988 Chevrolet Suburban with 95K miles. It’s a 4X4, 3/4ton (disk/drum), 4 speed manual, big block.
The current DRIVE TRAIN in my 72 SWB K10 is a 350, TH350, 203 transfer, and six lug bolt pattern on the axels. Going to swap the motor, tranmission, rears, transfer case. My questions for the board are: •Will the rears fit without moving the springs? •Will the 454 fit in a 4X4 engine compartment? Read the BB motor needs to be moved but can’t find the thread •Will the shifter come through the floor at a useable position? •Has anyone had a drive shaft balanced? Does it really make a difference? Any and all lessons learned would be appricated. Dale_Brown Last edited by Dale_Brown; 02-07-2013 at 05:15 PM. Reason: S |
02-07-2013, 05:07 PM | #2 |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Re: Major swap in my future
Sorry, I am bit confused
Thread says drive line; perhaps you meant drive train ? |
02-07-2013, 09:16 PM | #3 |
to answer your questions
if you are just going to put the rear axle in and leave the 1/2 ton springs yes it will work if you are running a HEI dizz move the crossmember forward 1-1 1/2" to allow clearance I am not sure on the transfer case shifter, what transfer case? I think that 88 has the shifter on the drivers side?? again not sure. YES balancing a drive shaft is DEFINATELY worth the money. Coop
1971 K20, Coop's beast (project) 1972 C30 wrecker, "Big Ernest" (SOLD) 1975 K5 Blazer (wife's toy) she got it in the divorce 2014 Street Glide Special 1983 K20 Big Block, auto (work horse) |
02-08-2013, 02:58 AM | #4 |
Spring spacing is 40.5" for 67-72's
spring spacing is 42.5" for 73-87 1/2 and 3/4trucks, til 91 for blazers and subarbans Spring spacing is 40.5" for 73-89 1 ton trucks |
02-08-2013, 04:33 AM | #5 |
Collector of Projects
Stock transfer case for a 72 would be the NP205, not the NP203. Not sure if you actualy have the NP203 or not, just making an observation...
02-08-2013, 02:21 PM | #6 | |
Thanks all for your input. Between your post and what I can find on the board it should be painless. Keep the information comming! |
02-08-2013, 03:09 PM | #7 |
Windy Corner of a Dirty Street
Is the donor Suburban really a Big block? Big blocks did not appear in 4x4 Suburban’s until the next body style in 1992. Maybe the PO swapped it in?
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
02-08-2013, 04:44 PM | #8 | |
Ill root around an see if I can get a casting number. Did not take delivery as the weather $ucks here. COME ON SPRING Last edited by Dale_Brown; 02-08-2013 at 04:52 PM. |
