Need Help with Brakes!!!
Im done! I cant take it anymore. Ive ordered hundreds of dollars of parts from companies that assured me they were correct for my truck and they are all wrong. The truck is a 67 GMC 3/4 ton with a Dana 60 rear end and leaf springs. Can anyone help me find a supplier that can get me the right stuff? Im done with LMC.
I have attached a photo of my brakes. There is only one spring and pin holding each shoe on the backing plate that I think if they would just open the box and check that would be a clue as to if it is the correct spring kit. I need a spring kit, automatic adjuster, and the pins that go into the wheel cylinder and push against the shoes. At a minimum I need the one spring that goes onto the spreader bar. Its the bluish gray spring in the pic on the right shoe. Its kind of oval shaped. If anyone has this spring and is willing to part with it please let me know. My driver side one rusted to pieces. Any help would be appreciated. |
Re: Need Help with Brakes!!!
perhaps you can elaborate on what goes wrong in the ordering process?
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
Active Member
![]() Join Date: Jul 2007
The problem is ordering mail order when you can get the parts locally. Try NAPA or Carquest. I did my 1/2 ton, leaf, Dana 44 couple of years ago with local parts.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Josh '70 Custom Camper / 20 |
brakes and axle and suspension stuff seems to be so varied and so many options I plan on just removing one side and taking the parts with me to the local store. Seems like to much of a crap shoot to order over the internet and return stuff and wait around for those type things.
We did my 69 c-10 complete brake job with parts local. Do what JT suggests. Good luck!
Dan |
yep get over your fears and go into the local store look the live human in the eyes and talk to him or her and get stuff like they did way back when
![]() Join Date: Aug 2006
Stay out of the chain stores like Advance or Autozone. Go into the parts store that has been around for years, either unaffiliated or NAPA. That will be your best bet. I did my HO52 with the local mom & pop store that all of the local "good" garages use. Totally pain free. Spent some time with them over the parts books and had the right parts the first time. Good luck.
LOL Thanks been there done that. NAPA, Autozone, and Advance. I stood at the counter at NAPA with the every single part in a box. They only had ONE part that matched my brakes, the wheel cylinders. Note in the NAPA link it says 11" brakes. I have 12" brakes, 2 1/2" wide shoes sorry not on the list for hardware. NAPA has been great with everything else but dead end on the brake hardware. I went with LMC because it was in the catalog as having parts that met my needs 67, GMC, 3/4, w leaf springs. I have found a source that said he could help me. www.Vintagechevytrucks.com He assured me he had the parts but wants me to send pics to be sure. So I am waiting for a call back. RLM316 I will do that. We have a mom and pop store like that not to far away that I forgot about. |
Just in case vintage cant help me does anyone have the a spreader bar spring they could part with? Its the bluish looking spring with 5 coils spread apart pressing on the right brake shoe.
Alot of these parts are interchangeable with other years and models. Take some measurements of the spring and someone will surely have something. It looks like a standard tension spring from the pics. Won't know until you post measurements.
Active Member
If NAPA or Carquest can't help you, you may be talking to some new person or someone that can't look up parts. The internet shows the 2.5" brake shoes on the NAPA site plus associated hardware for you area. Personally, I would go to a different NAPA.
#13 |
I am a Referee of life.
You'll need a parts man,not parts boy.It will have o be someone old enough to have really learned to read in school and who is smart enough to know how to look up stuff in the BOOK.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#14 |
![]() Join Date: Oct 2009
I feel your pain. Just went through this on my 71 with Dana 60 and leafs. It sucks and it's not as simple as ordering C10 parts. The variations available on the 3/4 tons make it very difficult - leaf/coil, Dana/Eaton, 2" or 2.5", etc etc. In my brake rebuild, I managed to get the wrong drums, wrong shoes, wrong hardware, and wrong self-adjusting hardware over multiple trips to the stores. On some items, found out that some places simply do not carry it for that combo or their inventory system isn't specific enough to narrow down what you need. Here's what finally worked (almost):
H7128 from O'Reilly - Rear brake hardware (1 set covers both sides) $7.75 PAB419R from O'Reilly - Rear brake shoes (full set both sides, Wagner) 12"x2.5" $35.14 2071DGS from O'Reilly - Rear Brake Drums $57.81 each WC34474 from O'Reilly - Rear Brake wheel cylinder (L) $37.59 WC34475 from O'Reilly - Rear Brake wheel cylinder (R) $37.59 H2508/H2509 from CARQUEST - L & R rear brake adjusting hardware/star wheel $15.26 each Even with that, the self-adjusting hardware kits (both sides) still have the wrong size star wheel retaining arm (not sure what you call it, but it's the lever arm you pry up with the screwdriver (or brake tool) when the drum is on so you can then spin the star adjuster wheel with another tool). Both sides have an arm that is too short. But, it's just a chunk of metal, I cleaned up and re-used the original. This was after a similar amount of hair pulling and hand-wringing and multiple trips to both stores. I prefer to not mail order brake parts because it adds so much hassle when I inevitably have to return them. It's enough of a pain to have to drive down the block and explain to the 12 y/o behind the counter why it aint workin.... Having said all that - keep in mind these part #'s are for a 71, there are a few differences I'm sure. Of course... |
#15 |
I ordered my stuff from RockAuto. It was all correct. I try to only order from LMC what I can't get from auto parts store. Reproduction type stuff.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
#16 |
I got that particular spreader bar spring through CarQuest, although the CQ I go to has a parts man instead of a parts boy
![]() ![]() ![]() It seems that spring don't come in any of the 'complete kits'. Inline tube has a lot of off-the-wall brake parts, too.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#17 |
Awsome!!! Thats for the tips Jocko and Pritch.
Airdale I looked at rockauto and did not find what I needed. Some stuff sounded right in the description but did not match the pic. Which may or may not be a generic pic but at this point Im not going to take the chance. |
#18 |
Pleaseant turn of events!! The spring and adjuster kit that was supposed to be for my Dana 60 with 12" drums is actually for the front 11" drums so I don't need to return them after all.
Will be hitting o reilly and advantage tomorrow to see if they can match up what I need for the rear. Thanks again for all the help this site is awsome!!!! |
