Old 02-08-2013, 12:16 AM   #1
cagodinez
cagodinez's Avatar
hydroboost pressure lines?
I'm running a hydroboost from a mid 90's astro van, what lines are you guys using to ps pump and gear box? My truck is 67 with a 5.3/4l60e and I have a 1984 (metric) gear box. Can I use lines out of a 2002+ 2500HD silverado?
cagodinez is offline   Reply With Quote
Old 02-08-2013, 10:55 AM   #2
ls1nova71
ls1nova71's Avatar
Re: hydroboost pressure lines?
You can use the 2002 hose from the pump to the HB. From the HB to the box I used one from a 96. Had to bend the box end but wasn't too bad.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-08-2013, 05:31 PM   #3
cagodinez
cagodinez's Avatar
Thank you LS1NOVA71
Old 02-09-2013, 01:14 AM   #4
ls1nova71
ls1nova71's Avatar
On my orange truck, I used the 2002 and 1996 lines, and it works, but they come in from different angles, there's a pic in my build thread for my rusty '71 in my sig, post #71. On the rusty '71 I ended up using all the lines from the '96, and they look a little better since they all come in the same side. There are pics in the same thread on post #82. Hope this helps.
Old 02-09-2013, 01:41 PM   #5
cagodinez
cagodinez's Avatar
Thanks man, your swaps are so clean!
Old 02-18-2013, 10:21 AM   #6
OneOffStroker
http://67-72chevytrucks.com/vboard/s...d.php?t=523502
Here is a thread I started on this very topic. Should lead you in the right direction, if you haven't already completed it.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 04-01-2013, 12:39 AM   #7
cagodinez
cagodinez's Avatar
Good info! Thank you ONEOFFSTROKER
