84 454 wont run, engine swap
I have tried everything. Its a 454 out of another truck that was running great, I resealed it and touched nothing internal. Everything was tight and in shape, its all stock, except for an edelbrock off of another big block. I have tried the wore out quadrajet that was on it and it acted the same as well as two stock distributors, I had spark with both of them. All vaccum ports are blocked off or routed to there spot, just a vaccum advance, pcv, and brake booster. It has fuel to the carb (hit the throttle and the accelerator pump sprays fuel, timing anywhere from 0-12 degrees advanced at (changed it while ****ing with it. I can get it to run a bit if I pour fuel down the carb but it eventually dies. lots of raw fuel... Thats all I have I think, I just dont get why it wont run...
Re: 84 454 wont run, engine swap
Has the 454 ever been rebuilt or stripped down as far as you know?
1983 Chevy C10 LWB 305 SBC bored .030 with cast dished pistons Summit RV Camshaft 204/214 .424/.444 416 Iron Heads Performer Intake, Quadrajet, and Flowtech Long Tubes TH350 2.73 10 Bolt |
nope. But it ran great before it was pulled.
do you live/work in quincy? i have seen a truck just like yours when i pass through there
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
![]() Join Date: Jun 2010
Did the truck that you put it in run right before the swap? Has it sat a while to where there might be a wiring issue somewhere. Not sure what might be going on there. If you have both fuel and spark then you should be good to go I would think. Have you rechecked for a big vaccum leak. That happened to me once on a 3.8L Grand Prix, it would start and then die. Left the rear vaccum for the brakes open and it wasn't responding to well.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#7 | |
Just here to tinker
![]() Join Date: Jun 2008
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
No it lost compression after way to many wore out miles... I'll grab another carb gasket lol. I've triple checked for vacuum leaks but that seams to be the only answer
Posted via Mobile Device |
No vacuum leaks anywhere. Good spark and timed right. Figured maybe its 180 off (spark on exhaust stroke) put it back together and now it's got flames out the carb. So I'll be pulling the valve cover off tomorrow and making sure its right (should have done that before switching it around Nd second guessing myself). Anyone have some food for thought for me?
I didn't want to think about a cummins yet$ but right now it's sounding good considering I work on diesels 40 hours a week:/ Posted via Mobile Device |
Any more ideas on possible problems or experience with this?
If you can get it to run for a few seconds I would loosen the distributor and have someone turn it backward or forward while it is running.
The timing mark on harmonic dampers can shift over time. Then I would try someone else's carb on it P.S. I have had similar responses from an engine when I put the spark plug wires on one off (i.e. I cylinder retarded). Last edited by tinydb84; 02-09-2013 at 11:21 PM. Reason: more info |
![]() Join Date: Feb 2013
Sounds like a fuel delivery problem. If you can get it to run by pouring gas down the carb. I know it is getting some gas, but is it getting enough? When it runs, does it run like sh*t?
If you are blowing flames out of the carb you have it advanced too far. I didn't really understand that part of your post. I'm sure you know that.. Check your plug wire fireing order maybe. Make sure you didnt crack a plug on the swap. I can't figure out why it will run when you pour gas down it, and not from the carb. |
#13 |
It will turn out to be something simple. Check your plugs.
#14 |
Where did you get the engine and truck? Guy by Monroe by chance?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#15 |
#16 |
i had this same type of problem once, turned out that the fuel filter was plugged. there was enough fuel for the accelerator pump to work, but it wouldnt fill the bowl enough to stay running. might be worth checking on, good luck with it.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold 1986 suburban 350/700r/3:73's 31's: parted out. 1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold 1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold 1970 c10 long bed-new project! getting ready for the 6.0 |
#17 | ||
Brand new plugs
#18 |
Whew. Glad it wasn't the bbc I was trying to work on for a guy. Couldn't get it to run no matter what! He sold it. Only thing I could think of was his pistons had holes or something lol
#19 |
its not getting enough fuel i had the same problem right this afternoon float was stuck, unstuck it, same problem. find out later the dual fuel tank switch valve wasnt working ,by passed it (only run 1 tank now anyways) and voila worked good. lost 2 hours tough wasnt planning on doing this but anyways
#20 |
I guess I'm going to borrow a carb and try it. I'm out of ideas. I really feel like everything is perfect. It's timed right and I have good fuel pressure to the carb.
#21 |
78K & 79C Jimmys
try from a gas can ,rule out the whole line as an issue
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#22 |
I was going to post the same thing. Also how is it running when you pour gas down the carb. Does it seem like it is running decent. I have used those clear ketchup bottles that has the tapered spout. Makes pouring a little easier to control. You can keep it running that way quite a bit longer to try and troubleshoot. Beats just pouring big gulps of gas at it.
#23 | |
78K & 79C Jimmys
#24 |
It runs, not great but it runs.. Next up is a compression test. It's definitely not burning good when it does run, lots of smoke, it smells like fuel.
So good fuel pressure Good spark Correct timing Carb *seems* good. Posted via Mobile Device |
#25 |
So I did a dry compression test and came up with numbers between 120psi and 140psi. Seems really low. But could be because the cylinder walls have been washed with fuel and its been sitting for a week. Didn't test all cylinders cause it was dark and COLD...
