Old 02-08-2013, 09:23 AM   #1
29od1
Tilt Steering Column Parts
Does anyone know what the part numbers are for all the bearings for tilt columns?
I find it difficult to pay $30 for one bearing that I know I can get for $5-$10 from a bearing company like IBT.
Thanks for any help!
29od1 is offline   Reply With Quote
Old 02-08-2013, 12:56 PM   #2
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Re: Tilt Steering Column Parts
I cant help but am interested to know also. I have a column that needs rebuilt
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 02-08-2013, 09:17 PM   #3
29od1
I know someone knows, we just have to find that guy!
Old 02-08-2013, 09:30 PM   #4
Dave
DND Trucks
I'm assuming your looking for the GM p/n. If so, here's the bottom bearing that generally needs to be replaced 7809271.
Dave is online now   Reply With Quote
Old 02-09-2013, 02:30 AM   #5
FirstOwner69
FirstOwner69's Avatar
Send a PM to KevsClassics. He restores these columns.
FirstOwner69 is offline   Reply With Quote
Old 02-09-2013, 01:30 PM   #6
jaros44sr
jaros44sr's Avatar
I did mine a year ago, and at that time few bearings were available. Got mine from Wes, he found one in south america....
For safety sake, i would use oem parts. Ive looked on my old bearings, and there arent any numbers etched in them....
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 02-09-2013, 05:36 PM   #7
Wootdog
Wootdog's Avatar
And Kev does a great job.
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 02-11-2013, 08:27 AM   #8
29od1
So I found a parts list reference with the GM part numbers on it for a tilt column.
Upper and lower bearings contained in the tilt housing, 5698407 (upper) and 5696210 (lower).
And I agree with Daves input that the lower shift tube bearing is 7809271.
Now the question is, who can cross reference these to a Timken (or similar) bearing number??
Old 02-11-2013, 11:58 AM   #9
jaros44sr
jaros44sr's Avatar
There are three bearings in a tilt, upper upper, its the one with a split retainer ring
SAFETY FIRST
AS usual, off topic
Jim
Old 02-11-2013, 12:19 PM   #10
29od1
I believe I described and listed the 3 bearings.
Old 02-11-2013, 01:09 PM   #11
jaros44sr
jaros44sr's Avatar
Sorry, reread.... Looks like you are correct
SAFETY FIRST
AS usual, off topic
Jim
Old 02-11-2013, 02:01 PM   #12
motorcritter
motorcritter's Avatar
Get the dimensions- OD X ID X Width- a decent bearing supply house should find an equivalent. Take 'em down to get matched up, if necessary.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 02-11-2013, 02:09 PM   #13
29od1
Good idea. I sent an email out this morning to a guy I know that runs a bearing company and he said to send him the 3 bearings and he'd try to match them up.
He had no luck converting the obsolete GM part numbers into a current part number.
Old 02-11-2013, 02:11 PM   #14
AirSpeed
AirSpeed's Avatar
I've replaced bearings in many machines, boat motors, trailers, stuff like that. I just take the old bearings in to napa, they measure them and give me a new one. So far they have had every bearing I took in. You might want to make friends with the guy behind the counter!
AirSpeed is offline   Reply With Quote
Old 02-11-2013, 02:23 PM   #15
29od1
Hopefully I'll get some part numbers back for current production bearings and post them on here so everyone can benefit from the findings. After all, that's what makes this website and this hobby great, because we can all learn from each other.
Old 02-11-2013, 08:56 PM   #16
Dave
DND Trucks
Smile Re: Tilt Steering Column Parts
You are absolutely right!
Old 02-13-2013, 01:36 PM   #17
ChevyCruizer
17's too small
Here is Kevs page
