Old 02-08-2013, 04:18 PM   #1
67 chevy heaven
Power steering gear box ?
Ok so I have a 67 Chevy truck that was a manual steering truck.
I pulled the old MSGB off and am trying to install a power steering Gear box from off of a 72 Chevy truck.
The problem is the back of the top of the gear box is hitting the riveted core support l bracket!!!!
Is there anyone that has run into this before???
My frame does have the dimples to get proper alignment
Therefore to eliminate the need for shimming.
Can anyone help me?
Is there a differance between a 67 and a 72 PSGB??
Any insight will be appreciated
Shawn
67 chevy heaven is offline   Reply With Quote
Old 02-09-2013, 11:58 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Power steering gear box ?
Can you post a picture?
I've never heard of this happening.
Keith
Convert to disc brakes.
Old 02-09-2013, 12:20 PM   #3
nds1968
nds1968's Avatar
This may help http://67-72chevytrucks.com/vboard/s...ing+conversion
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 02-09-2013, 01:02 PM   #4
67 chevy heaven
NDS 68
That pic is exactly what I'm up against!!!
Identically!!!!
I do need to dimple my frame but...
Will that give me enough clearance to get past the core support bracket or
Will I still have to cut/ grind it to match?
PS:
I do have pics but I can't figure out how to load them.
But the pic in the link provided is what my pics look like
Your thoughts and info really are appreciated
Shawn
Old 02-09-2013, 01:23 PM   #5
joel.e
joel.e's Avatar
I had to cut the support on my '67 as well as clearance the frame since it wasn't originally dimpled.
joel.e is offline   Reply With Quote
Old 02-09-2013, 01:26 PM   #6
67 chevy heaven
So even though I am going to dimple the frame ill still have to
Cut the bracket??
Old 02-09-2013, 01:33 PM   #7
joel.e
joel.e's Avatar
Yep. If yours looks like mine. Dimple the frame just allows the steering box to sit flush on the frame mounting points. Then the longer box interferes with the brace so you have to clearance for that also.
Old 02-09-2013, 02:04 PM   #8
nds1968
nds1968's Avatar
Yeah I had to cut mine, I just used a cut off wheel. You may also have to notch the bumper bracket. Nate
Nate
Old 02-09-2013, 10:08 PM   #9
MyDad'sTruck
I got mine in with a adapter plate and have had no problems. My frame was not dimpled at all. Will try to post pics.
MyDad'sTruck is offline   Reply With Quote
Old 02-09-2013, 10:53 PM   #10
67 chevy heaven
Great
Pics would be appreciated
Old 02-10-2013, 12:25 AM   #11
nds1968
nds1968's Avatar
Here is another thread http://67-72chevytrucks.com/vboard/s...d.php?t=545971
Nate
Old 02-10-2013, 05:09 PM   #12
MyDad'sTruck
If I do this right, you will see photos of my power steering gear box, the adapter plate between it and the frame, and a photo showing the steering column that was installed. The column is a bit off center, but it steers well and does not wander at all at high speed on the freeway. Before I put the inner fender or wheel well back in, i had to cut it back to fit around the gear box.
Old 02-10-2013, 07:44 PM   #13
67c10rustbuket
67c10rustbuket's Avatar
Yup, 67 must be dimpled, and clearance core support mount, and reportedly clearance the bumper bracket too.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-11-2013, 09:01 PM   #14
67 chevy heaven
Thank you all for the pics and all of the advice
It is greatly appreciated!!!
Old 06-06-2013, 04:41 PM   #15
Jamminjohn
can you heat up the frame with a small propane torch and hammer in the dimple or do you need a bigger torch to do so?
thanks
Jamminjohn is offline   Reply With Quote
Old 06-07-2013, 11:56 AM   #16
joel.e
joel.e's Avatar
Wink Re: Power steering gear box ?
Depends on the size of your hammer. Some where on here there was someone who cut a slit at the top and bottom of where the dimple would be, heated it up, and beat it in. That's what I did and then just welded the cuts up.
