Old 02-08-2013, 06:10 PM   #1
twangismythang
twangismythang's Avatar
lowering options, cutting coil springs? tires sizes
I am close to getting it on the road, original big block truck now sits a little high in the front. I like the idea of lowering the entire truck a tad bit to give it a better stance. I have read a little on some folks cutting a coil off of the springs to lower it. SInce im sure I have original coils, I am not against cutting them if it will give me the desired stance. My questions are does it make the truck ride any worse with the cut springs and how big of a task is it to cut them?
Any assistance would be great, also looks like I may have found a set of 6 lug steelies, so I also have questions regarding what tire sizes to run. HOw wide of a wheel can I put on the rear with the stock width wheel and what size should I run up front to fill the space up as much as possible?
Victory will only be achieved through superior firepower and trusting in the Lord.
SOLD 68 C-10. http://67-72chevytrucks.com/vboard/s...d.php?t=560975
SOLD 2000 Silverado...http://67-72chevytrucks.com/vboard/s...=1#post6492671
87 V-10 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=643898
twangismythang is offline   Reply With Quote
Old 02-08-2013, 06:19 PM   #2
Rastis
Re: lowering options, cutting coil springs? tires sizes
Essentially, a coil spring is a torsion bar. Cutting it down will increase the stiffness of the ride.
Rastis is offline   Reply With Quote
Old 02-08-2013, 07:30 PM   #3
Hotrob72
Hotrob72's Avatar
Hell, they been cutting springs since the ol' days........
Just wouldnt be my choice.
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline   Reply With Quote
Old 02-08-2013, 08:00 PM   #4
greenmacheene
We cut my coils and don't regret it. It was quick and easy and don't notice much of a difference in the ride if any.
greenmacheene is offline   Reply With Quote
Old 02-09-2013, 09:51 AM   #5
twangismythang
I guess I will be cutting mine soon, I am picking up my steel wheels this morning just need to score some tires for the cheap now. Cant wait to see how she looks lowered.
