Old 02-08-2013, 09:24 PM   #1
Silverray76
Silverray76's Avatar
Transfer case brace
Hey guys picked up a 79 k5 not to long ago and today my friend had come over to check it out. He gets under the truck and notices that the transfer case is loose and starts to move it rapidly which also made the trans and motor move. Also he tells me there is a part missing on the transfer case because there are 2 open slots where something needs to be. I found out that there is a brace missing. Anybody have any pics of the braces hooked up and maybe point me into the direction of where i can get one. Im afraid that something may happen like it falling off while i drive
1976 c10 stepside 350/350 My baby
1991 suburban 1500 350/700 The hauler
Silverray76 is offline   Reply With Quote
Old 02-09-2013, 02:43 PM   #2
kwmech
Re: Transfer case brace
If you are talking about the brace that bolts to the side of the t-case and anchors to the frame...........finish removing it and leave it off. The drivetrain needs to flex some and the brace prevents this eventually breaking either the transmission case or the adapter, assuming it is an automatic. It won't hurt a thing by removing
Old 02-09-2013, 07:44 PM   #3
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Regardless of whether or not that side brace is in place you must have some other issues if there is that much movement by hand... I would be checking condition of your transmission and motor mounts.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-09-2013, 08:44 PM   #4
psuedopimp
psuedopimp's Avatar
Check the transmission to transfer case adaptor. Maybe you are missing a bolt there
psuedopimp is offline   Reply With Quote
Old 02-10-2013, 11:02 PM   #5
Rust_phoenix
Rust_phoenix's Avatar
X2 on the missing mount bolts, i have seen motor and transmission mounts that have been oil soaked detiorate and fall apart also. here is a link to the correct type bracing for your blazer http://67-72chevytrucks.com/vboard/s...d.php?t=510109 as of late december he still had them, the mounts that have been mentioned earlier by others were for older trucks with the NP205 t-case, many post have been written about them and breakage supposedly caused by that brace as it mounts to the frame, unlike the newer model that goes from the bellhousing to the t-case.
My build: Project "Lazarus" 8.1 Vortec and Allison in a 72 swb k10
http://67-72chevytrucks.com/vboard/s...d.php?t=555878
Rust_phoenix is offline   Reply With Quote
Old 02-13-2013, 06:25 PM   #6
muddnutz
muddnutz's Avatar
My brace goes from transfer case to motor mount. I just removed my tranny and had to pull it off
1986 K-10 "ole blue"
muddnutz is offline   Reply With Quote
