Old 02-08-2013, 11:21 PM   #1
BlueJeep
BlueJeep's Avatar
Fuel lines for 5.3
I'm really only starting to research what to do about fuel lines for my 5.3 swap. Looks like most people go the AN fittings and line route. Is there any reason to NOT double flare the stock 5.3 fuel lines after the flex line, and then run standard parts-store grade 3/8 and 5/16 hard lines back to the tank? Seems as if a double flare can hold up for a braking system, it should be more than enough for 58PSI fuel system. Not interested in bling, just functional and safe.
Is this a good idea/bad idea, and why? Thanks!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-09-2013, 12:24 AM   #2
oldman3
oldman3's Avatar
Re: Fuel lines for 5.3
I would also be interested in this hard line setup...Jim
oldman3 is offline   Reply With Quote
Old 02-09-2013, 12:54 AM   #3
ls1nova71
ls1nova71's Avatar
Not a bad idea at all. I've been doing it this way for years with absolutley no problems.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-09-2013, 01:58 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm running 3/8 feed and 5/16 hard line for about 85% of my system. I only have stainless braided line for a foot or so at the rails, and off the tank.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-09-2013, 12:24 PM   #5
Kim57
Kim57's Avatar
This is basically what I did with mine. 3/8" hard line with double flares except at the tank filters and engine.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-09-2013, 03:07 PM   #6
BlueJeep
BlueJeep's Avatar
I read through your build, nice work on keeping the cost down! Do you just use "normal" parts store compression fittings or are they something special?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-11-2013, 12:30 AM   #7
71chevystep4x4
71chevystep4x4's Avatar
I just got mine going two weeks ago, ran the entire fuel system hard lined, with all standard compression fittings and lines from Baxter Auto parts. they werent even double flared because I didnt want to spend the money for a fancy double flareing tool. Only leak I encountered was at the post filter fitting that I forgot to seal with teflon tape.
71chevystep4x4 is offline   Reply With Quote
Old 02-11-2013, 01:25 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You are not supposed to use Teflon Tape on gasoline lines.
There is a special hydraulic and gas compatible tape but its not the usual hardware store stuff. Tef tape dissolves.
Old 02-11-2013, 03:37 PM   #9
ls1nova71
ls1nova71's Avatar
Yes, I used normal parts store compression fittings. The brass fittings with the brass ferrules will crimp down a piece of stainless fuel line, so I don't for see any problems, and it's running and nothing is leaking, but I haven't had this truck on the road as of yet. Also I agree with BR3W, I don't use teflon tape on gas lines, or any flare fittings.
Old 02-11-2013, 08:36 PM   #10
71chevystep4x4
Ok I was wandering about that. wont take long to reseal with something else, maybe the liquid thread sealer????
Old 02-11-2013, 09:11 PM   #11
wgeyer88
Is anybody using Nylon fuel lines similar to the OEM lines on newer cars and trucks?
This kit seems to be popular and pretty cheap compared to some of the other options out there:
http://www.ntxtools.com/network-tool...RR-KP1200.html
Any feedback on this?
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 02-11-2013, 09:46 PM   #12
cwii
I was looking at the same kit from tooltopia.com for $136 and free shipping.
"S.U.R.& R. nylon fuel line kit #KP1200"
But I do like the idea of a solid line with the ability to have some type of a flexible hose on both ends.
Sorry I ain't smart enought to post a link...
Chuck
cwii is offline   Reply With Quote
Old 02-11-2013, 09:58 PM   #13
joesgreen67
joesgreen67's Avatar
Chuck
Im running that kit myself....very easy complete kit
joesgreen67 is offline   Reply With Quote
Old 02-11-2013, 10:47 PM   #14
BlueJeep
BlueJeep's Avatar
Can you post more info? Did you like it, pics, etc?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-11-2013, 10:58 PM   #15
joesgreen67
Sorry i didnt take any pics. I was pretty happy with the kit. I did have to buy a fitting that wasnt in the kit (i forget the number). Other than that it was complete, right down to the tubing cutter and clamping tool.
