Old 02-08-2013, 11:47 PM   #1
GMtrucknut!!
GMtrucknut!!'s Avatar
Smile LOKAR cable shift
Has anyone used the Lokar cable shift setup on their 55-59 Chevy trucks? I am thinking about it or the Ididit set up. I was just looking for a few opinions
GMtrucknut!! is offline   Reply With Quote
Old 02-09-2013, 12:14 AM   #2
OKGMC4
OKGMC4's Avatar
Re: LOKAR cable shift
I had to have it to make my column shift clear my 5.3l. I guess the LS engines are wider and I had to run the shift arm 180 degrees out, impossible with a linkage shift but the cable was perfect. Works great!
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 02-09-2013, 07:02 PM   #3
OrrieG
OrrieG's Avatar
I looked at it but found it was cheaper to make my own using a B&M racing shift cable and trans mount kit from Oriellys. I made my own firewall bracket. You can see it starting here in my build thread.
http://67-72chevytrucks.com/vboard/s...&postcount=447
OrrieG is offline   Reply With Quote
Old 02-10-2013, 10:22 AM   #4
Muleman100
Muleman100's Avatar
I used a Lokar bolt on shifter on my TH400. I like the looks and it shifts good having to depress the button to go into park or neutral.
" I never think of the future. It comes soon enough " - Albert Einstein
Muleman100 is offline   Reply With Quote
