![]() Join Date: Nov 2012
which oil to use?
Just wondering what brand and weight oil to use on my 140000 mile ls pullout.
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
meowMEOWmeowMEOW
Re: which oil to use?
Since its higher miles and you don't know what type of oil its had most its life, I'd probably just run a good high quality dinosaur oil, at least for a little while. With high miles, you'll need to replace some seals or leaks, and there's no reason to put $8qt oil into a high mileage pulout and then leak it all out.
If its a SUPER clean engine and doesn't leak or burn anything, or if you plan on doing a rebuild on it, then for any performance/hobby car, a top quality synthetic is where its at. I've run Royal Purple, Mobil 1, Redline (all 5w20 or 5w30 depending) with good results.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Jun 2006
I would think the High Mileage Mobil 1 would be a good choice. I have used it in my 4.3L V6 from about 140K miles to present which it now has over 225K miles and still running strong.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
