How long is your dipstick?
I have a first generation 350 with a stock pan. When I change the oil it shows that I'm overfilling when I put in five quarts of oil. I'm thinking the dipstick is too long and not giving an accurate reading.
Your thoughts?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: How long is your dipstick?
I believe the stock GM dipstick is 6" long from the shoulder (where it meets the block) to the full line, and 7" from the shoulder to the empty line. I went through this because I have a 7-quart pan on my 383 stroker and checked it out when I changed over to the large pan size.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
Your mind might be in the gutter when..... lol
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
"Now that's thinkin' with your dipstick Jimmie!"
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
![]() Join Date: Feb 2003
hey! lets keep it clean.... hehehehe
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
An innocent guy posts a subject and every else's bad minds chime in
![]() To answer your question, mine's 18 1/2 inches.
71 K20 64 GMC mud truck |
Here are all of them from the 46-72 parts book in case you need to ID something laying around.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Active Member
![]() Join Date: Jul 2007
Is that 5 quarts with a filter change? Just making sure...
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
C/10 junkie
Long enough to get oily
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Everytime I put 5 full quarts in after an oil & filter change, it would read over the full mark. That's been the case with every stock SB Chevy motor I've had.
Now I put in 4.5 quarts and the level reads between the marks. After I burn/leak a little, then I add that leftover 1/2 quart. 5 full quarts probably came from the old days of punch top oil cans, you poured it all in. Probably doesn't hurt anyting. With the plastic re-sealable jugs today, just use the amount needed. |
Old member
My 305 will read over full until I crank it up and run it to get the oil filter full. Most of the time though I fill the filter up before I install it then crank it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#12 | |
Yes.
Kind of reminds me of that old joke about two guys standing on the river bank taking a leak. First guys says "man, that water's cold." Second guy responds: "Yep, and it's deep too!" ![]() Sorry, I couldn't resist.
#13 |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
The size of the oil filter also makes a differance. There are long and short versions of oil filters. The long filter will give you the correct oil level on the dipstick.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
#14 | |
I liked to use the old PF35, even on my cars. Holds a couple extra swigs of oil. Some of the new filters today are quite stubby. |
#15 | |
I am a Referee of life.
porn star!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
