02-09-2013, 04:29 PM | #1 |
resident oilfield trash
Pros and cons of putting 6.5 speakers in the doors
What do you guys think horrible idea or not
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
02-09-2013, 05:05 PM | #2 |
Re: Pros and cons of putting 6.5 speakers in the doors
I wouldn't cause I like the "stock look" but if you can handle cutting them giver!
It would probably sound much better. Posted via Mobile Device |
02-09-2013, 05:32 PM | #3 |
I have them in mine because previous owner cut and had them in there, it does sound good with them plus the rear 6x9s but if mine weren't already cut I'm not sure if I could bring myself to do it.
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
02-09-2013, 05:54 PM | #4 |
Not a bad idea, you can also buy kick panels from q-logic
02-09-2013, 06:29 PM | #5 |
I did it but it has to be a componet set if you have power windows. With power windows the speaker will end up in about the center of the door on the carpet panel because of the motor. When you close the door the sound gets muffled by the side of the seat so a pair of tweeters on the dash is a must. I have a 6.5" kicker component set in mine and 6x9 fosgates in the back.
Zaccaglin 1998 Chevrolet C1500 Ext. Cab 350 Former Rig: 1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208 |
02-09-2013, 08:07 PM | #6 |
How are you going to keep moisture from destroying the speakers? This happens to all trucks I see with door speakers
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-09-2013, 08:14 PM | #7 |
Plus there vulnerable to get kicked when your getting in and out I just got 6x9s and made holders out of lawan wood and put them in each corner of the cab.
1967 gmc 4x4 factory air factory buckets 1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne |
02-09-2013, 08:24 PM | #8 |
your right, i had an 85 k5 for 11 yrs and wish i had never done it ....always kicked and hard to clean....my crew doors are still virgin...
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
02-09-2013, 08:35 PM | #9 |
when I changed my speakers to rockford fosgates the old ones were just fine
02-09-2013, 09:06 PM | #10 |
02-09-2013, 09:15 PM | #11 |
Or marine speakers
02-09-2013, 09:22 PM | #12 |
There are several different options you can go with they even make headliners that will hold speakers. I wouldn't cut holes in the doors because just incase you wind up not liking then your still stuck with the holes.
02-10-2013, 01:34 AM | #13 | |
02-10-2013, 01:36 AM | #14 |
I'm going to order some kick panels from the 73-87 board
02-10-2013, 01:42 AM | #15 |
po installed door speakers, replaced rear door & hated cutting a mint door so it would match.
02-10-2013, 03:17 AM | #16 |
I thought about that too but I know if I put speakers in the doors they'll get ruined since water goes down inside my doors...need to replace my weather stripping
02-10-2013, 03:30 AM | #17 |
Either way, if you look at that section of a door it is basicly flimsy and an acoustic drum. So you get panel distortion with horrible sound acoustics. so it really isn't the best place to mount a speaker. To fix this issues can cost quite a bit and with just the kick panel mounts that are now coming on the market it really makes no sense to me to hack up a door. I have yet to see a clean job on a door speaker lol
02-10-2013, 03:41 AM | #18 |
i put sound deadner & mlv in my doors so it sounds real good, but with that depressed section of the door, it does make the installation look goofy. if my doors had'nt been cut, i'd go kick panels & cab corners
02-10-2013, 08:02 AM | #19 |
fiberglass pod ?
02-10-2013, 08:03 AM | #20 |
1973-1987(91) Lower Kick Panels
http://store.73-87chevytrucks.com/me...y_Code=7387INT |
02-10-2013, 09:48 AM | #21 |
I have seen those kick panel pods and they blocked the e-brake from being fully depressed and I know those would get banged up by feet
02-10-2013, 10:32 AM | #22 |
what about these kick panel speakers?
02-10-2013, 10:46 AM | #23 |
I almost did it. I had a set of kicker marine speakers and I was thinking about cutting my doors and/ or my kick panels. but in the end I decide not too. just didnt feel right. I ended up using 3.5 in the dash. (prolly regret that decision).
02-10-2013, 11:53 AM | #24 |
very well may be true but he is a site vendor which i like supporting - im sure if there was any problems you could contact him with your issues
02-10-2013, 12:10 PM | #25 | ||
Happy to be here
Chris is a great guy to deal with, and I can assure you he won't sell a product that he wouldn't run in his own herd of 73-87 trucks.
