Old 02-09-2013, 05:35 PM   #1
haulnrat
haulnrat's Avatar
late model a/c into early suburban
Has any anyone done or have information on doing a air conditioning swap from a 88-98 c/k pickup. I have one I am parting out and wondered if it was worth taking the a/c out of it for my '72 suburban.
haulnrat is offline   Reply With Quote
Old 02-10-2013, 03:50 AM   #2
vectorit
What?
vectorit's Avatar
Re: late model a/c into early suburban
I am no A/C guy, but the compressor is probably the only thing one could use in a retrofit to an older rig. Maybe a few of the other small parts as well.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-11-2013, 10:55 AM   #3
Burbaholic
Burbaholic's Avatar
I went with the Vintage Air Kit. I know it's pricey but it's so clean and gets rid of all the vacuum doors and cable controls. I have the original A/C components that were removed carefully. PM me if you are interested as I was going to list them in the parts for sale section.
Burbaholic
1972 Suburban
Factory A/C - lowered 4 inches
383/700R4
"THE BLUE BURB OF HAPPINESS"
Burbaholic is offline   Reply With Quote
Old 02-11-2013, 02:05 PM   #4
haulnrat
haulnrat's Avatar
I put in Classic Auto Air. It works ok, but on hot days it doesn't keep up. I was thinking about swapping out for a late model a/c unit and add rear a/c. I have another project I could use the Classic Auto Air in. Just need something bigger for the 'burb.
Old 02-11-2013, 02:13 PM   #5
ERASER5
ERASER5's Avatar
Drew put a modern AC unit in his Frankinstien, so you could probably do it. Holes will need to be modified, the housing too. And if the AC don't fit, you can always a quit. Cardboard mock ups could save you a lot of time and less metal hacking. Of course as you remove the newer unit, compare the firewall holes, space under the dash, and things like that. You may lose the vent door, you may loose all or most of the glove box. And take pictures. Lots of picture.... for us of course.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
