02-09-2013, 05:38 PM | #1 |
late model a/c swap into early pickup
Has anyone done this or have information on swapping an air conditioning system from a '95-'99 c/k into an early truck. Let me know what the pros and cons might be.
Thanks in advance. |
02-09-2013, 05:43 PM | #2 |
Re: late model a/c swap into early pickup
I have had this in the back of my mind also. I think it may be a good fit for our trucks.
02-09-2013, 07:55 PM | #3 |
Its a Truck Thing......
I had a later model evaporator put into my original case with a sanden compressor, made lines and it works fine. Kept everything inside factory.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
02-09-2013, 08:56 PM | #4 |
Those trucks used a CCOT(cycling clutch orifice tube) type system so rather than running the compressor constantly and using a expansion valve to regulate the evaporator temperature they use a orifice tube and a low pressure switch to cycle the compressor to control the temp.
The major differences hardware wise is that the CCOT system has a accumulator after the evaporator rather than before the condenser, has a orifice tube before the evaporator instead of a expansion valve and the way the electrical is set-up slightly different. Ideally, you'd want to use the evaporator, the condenser and compressor from the donor truck but I suppose if you had a TIG welder you could modify the original evaporator and condenser to work. The electrical and having new hoses made would be the easy part. |
02-09-2013, 10:39 PM | #5 |
Old member
My 71. Factory boxes with late 80's components.
02-09-2013, 10:44 PM | #6 |
I'm dealing with a non factory air '72. So trying to make it look original is not a priority. I would plan on taking everything from the donor truck. I'm just not sure how big of a job it would be to remove everything. If would be worth it or not, but if I can save a $1000 over an aftermarket. Then it might be worth it.
02-09-2013, 11:40 PM | #7 |
i took a ac from a 1991 chevy truck and installed all the under hood parts into my 69 and left the inside factory controls and ducting alone. i had to modify the factory under hood air box to fit the 91 evaporator. here are a few pics
02-09-2013, 11:42 PM | #8 |
more pics
02-09-2013, 11:45 PM | #9 |
Great info here.
02-09-2013, 11:59 PM | #10 |
a few more pics of my airbox
02-10-2013, 12:08 AM | #11 |
02-10-2013, 09:59 PM | #12 |
Thanks for info nice work
02-10-2013, 10:23 PM | #13 |
bonnieclyde100, very nice work!
1967 SWB (small window) original 1970 4x4 STEP 1970 CST SWB FLEET 1972 SWB FLEET ORIGINAL |
11-02-2016, 09:02 PM | #14 |
Hey guys, I know this post is old, but I have a question for Bonnieclyde100, If he is still around, I am currently doing a 98 vortec swap into a 72 c10 and im swapping AC system too. before I cut the evaporator box to fit the 98 evap. is there a year model that is closer to the specs of my 72 evap.? Thanks in advance.
11-02-2016, 09:35 PM | #15 | |
11-02-2016, 09:56 PM | #16 |
Blazer and Suburban up until 1991 look to have the same (or similar) evap cases to the '72 case
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-03-2016, 04:15 AM | #17 |
11-10-2016, 02:41 PM | #18 |
Ok guys. I went with an 87 chevy truck evaporator. Fits pretty close I got my gaskets and compressor manifold in. Now I need to know what condenser will fit the best with standard (I assume) fittings, not metric. also what do I need to do about my orifice location. TIA
11-10-2016, 07:52 PM | #19 |
I wonder if cars are same as the truck/sub.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
11-10-2016, 08:31 PM | #20 | |
11-10-2016, 08:39 PM | #21 |
11-11-2016, 10:36 AM | #22 |
11-11-2016, 10:39 AM | #23 |
Old air products also sells the same condenser that Andy got from CAA. It is a bolt in deal
11-11-2016, 10:52 AM | #24 |
Old member
Correct, sorry just notice this.
Classic air group is the best. I've used them several times and never had a problem, well 1 time but they took care of it.
11-11-2016, 02:47 PM | #25 |
Thanks guys. Really appreciate your help.
