Old 02-09-2013, 07:04 PM   #1
DetroitIron
DetroitIron's Avatar
What might be causing this gas leak?
I am trying to get rid of this little gas pool on the manifold under the choke housing. Attaching pic. Checked most bolts and gas line. All good
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 02-09-2013, 11:15 PM   #2
DetroitIron
Re: What might be causing this gas leak?
Carb bolts are snug. Can't tell where the gas is leaking, but it's puddling under the choke housing. Any help?
Old 02-09-2013, 11:53 PM   #3
Duster
Duster's Avatar
It looks like it is coming from that upper gasket. It is hard to tell from the picture. It looks like there is fuel on top of fuel inlet. I can't tell though.
If it is running good you almost don't want to mess with it.
Duster is offline   Reply With Quote
Old 02-10-2013, 01:46 AM   #4
dieseldawg142
dieseldawg142's Avatar
have you checked your accelerator pump diaphram? hard to tell but it looks like fuel on the bottom of the inlet leading back to a.pump
dieseldawg142 is offline   Reply With Quote
Old 02-10-2013, 01:54 AM   #5
geezer#99
geezer#99's Avatar
Nothing wrong with the carb. It's coming from the bolt. It's crankcase vapour combined with a bit of oil. That bolt hole is open to the valley below the intake. If you use the wrong bolt or one with a lock washer and don't put some thread sealant on the bolt you'll get a little leakage there. THe bolt head needs to sit square on the intake. Most used a small flat washer like those used on exhaust manifold's.
Old 02-10-2013, 09:08 AM   #6
DetroitIron
Thanks guys. I'll explore further based on feedback. The bolt leaking vapor is one I did not even consider....maybe remove bolt and apply thread sealant and retorq
Old 02-10-2013, 04:25 PM   #7
6 Door King
Most gas leaks in my truck are caused by poor sphincter control.
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab!
1978 Crew Cab Dually roller
1982 C-30 Rollback, 454, 4 speed
2004 K1500 Suburban Z71 5.3 Kid Mover
6 Door King is offline   Reply With Quote
Old 02-10-2013, 05:51 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
It is prob coming from the throttle shaft. They get worn easy since the springs and throttle pull it back. This is why the correct way is to have the springs pull the throttle forward and the throttle cable pulls back. = a lot less wear.
The only way you can fix it is. A. New carb. B. rebuild(recommended) c. Motor swap with a holley haha
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-10-2013, 08:16 PM   #9
Duster
Duster's Avatar
Originally Posted by 6 door king View Post
most gas leaks in my truck are caused by poor sphincter control.
ha!
Old 02-10-2013, 08:30 PM   #10
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Wow, I'm going to have some sweet tea sticky keys on my keyboard for a while now....that was a good laugh though
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-11-2013, 08:01 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
looks wet in the right place,for shaft wear
you would see it drip,out/off the end....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
