02-09-2013, 08:15 PM | #1 |
Engine Bay clean up?
hey guys i want to clean my engine bay like removing things that is not important. i want to know what are something i can remove. here a pic if you g
guys can point out some stuff. |
02-09-2013, 08:23 PM | #2 |
Re: Engine Bay clean up?
The wires could be bundled up zip tied together and you can put that black plastic stuff on them, I can tell if that's a fuel canister beside your washer fluid but if it is that can go. You can get an A/C delete kit if that doesn't work.
1967 gmc 4x4 factory air factory buckets 1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne |
02-09-2013, 08:40 PM | #3 | |
http://www.porterbuiltfabrication.co...r-73-87-C10-65 |
02-09-2013, 08:45 PM | #4 |
Yes that should be it they have ones with holes in them to for whatever you want to stick through there I believe but if the A/C just needs a recharge I would keep it.
02-09-2013, 08:55 PM | #5 |
I would start by removing the dirt. You'd be surprised how good the engine bay looks even with all the wires and hoses when it's clean and all the plastic and hoses are nice and dark black.
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
02-09-2013, 10:05 PM | #6 |
but aint am i missing something to make the a/c work? idk what is called
02-09-2013, 10:06 PM | #7 |
do i just clean it it water and a towel or is there something special to clean it good?
02-09-2013, 10:07 PM | #8 |
Simple green is a very good degreaser to mix with warm water.
02-09-2013, 10:10 PM | #9 |
what are those 2 things that are next to to the windshield washer fluid?
02-10-2013, 12:00 AM | #10 |
You can get rid of your vacuum canister (if laws allow) along with the rest of the emissions crap and clean up the vacuum hoses. I believe that is a cruise control on your inner fender? I could be wrong though.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
02-10-2013, 09:26 AM | #11 |
That porterbuilt piece will delete both the heat and ac if you want to have heat only a kit like http://www.acdelete.com/pages/73-90_Truck.htm Pretty much everything else you need unless you don't want cruise control.You can buy metal tube style tanks to replace the coolant over flow and windshield washer tank.
02-10-2013, 10:24 AM | #12 |
The one with cable running to it is CRUISE CONTROL. if you remove that, you will need to replace the cable with one that bypasses the vacuum diaphragm. The other is a vacuum canister . If your emissions stuff is already gone, you can remove that. I recommend getting one from a newer truck that is just the for the fuel vent. Mines and 87 and has one, just to give you an idea of what years to look for.
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
02-10-2013, 10:27 AM | #13 |
The fuel line, you can bend that back and out it back behind the alternator where it was originally. The wires, as was said already, bundle them up or run them in a cleaner route, even tie them down.
02-10-2013, 12:16 PM | #14 |
What are your long term goals with the truck?
Daily driver ? strip? street and strip? That would give you an idea of what to get rid of. If its gonna be a daily driver, then I would just clean and tidy. Things like ac and defrosters are nice. Wives and kids may not understand why these things are gone when they are uncomfortable. If strictly a racer then you don't need ac, heater, power steering, windshield wipers, wheel wells |
02-10-2013, 12:20 PM | #15 |
Happy to be here
Before I offer advice, let me ask a question. Is this your daily driver? How long can it be down for the detail work. What kind of tools do you have access to? Do you have apaint gun and compressor?
Answer these questions, and I will offer more advice.
02-10-2013, 07:21 PM | #16 |
well it dosent pass the smog anymore so yea lol
02-10-2013, 07:23 PM | #17 | |
02-10-2013, 07:25 PM | #18 | |
02-10-2013, 07:33 PM | #19 | |
it can be a long time down for as much as i want,i mean its been siting there for almost a year already lol but i would start it once in while. about tools i have the basic tools,engine crane,floor jack i might have a paint gun but im not to sure, i don't have a compressor. |
02-10-2013, 08:29 PM | #20 |
Carb cleaner can blast off alot of grease off the intake. A K&n filter will look way better than that stained sock that's on there now
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
02-10-2013, 10:25 PM | #21 |
Just a one piece speedo cable. I don't think the two ends will connect just removing the vacuum diaphragm .... But your speedo will be off as well. You may need ot change the gears. The one I did years back, it threw the speedo off.
02-10-2013, 10:26 PM | #22 |
Well I looked at it closer , now I'm not so sure it's a CRUISE CONTROL UNIT
02-10-2013, 11:09 PM | #23 |
resident oilfield trash
Posted via Mobile Deviceim not deleting anything. I like the semi correct organized look
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
02-10-2013, 11:10 PM | #24 |
02-10-2013, 11:13 PM | #25 |
