Old 02-09-2013, 08:25 PM   #1
bodyman9174
emission delete
Hey everyone just picked up a 85 GMC with 4.3 manual trans. Going to change the valve cover gaskets. Well stared taking vac lines off and a lot were broken or just old and brittle. So I just started taking them off. Now thinking maybe I should have not do this. Been looking for post about deleting all this stuff but am finding like only one post that talks about doing this to a v6. Someone said will have to get a new distributor but did not tell why. This is the first V6 I have had. I have a vette that I pulled everything off with no probs. But sems like on the V6 its more of a pain. I got a new carb, Going to weld the tubes coming out of the manifolds. But what do I have to do about the distributor? Any one with the 4.3 take all the stuff off please help
Thanks Jay
Cars i have done
bodyman9174 is offline   Reply With Quote
Old 02-09-2013, 08:28 PM   #2
1967gm4x4
Re: emission delete
You should only need a vacuum line off you distributor to the carb and if you have vacuum operated vents. Most of the lines how from the motor to another spot on the motor and a lot of it you don't need. Chiltons manuals have vacuum diagrams I would get one if those.
1967 gmc 4x4 factory air factory buckets
1985 gmc high sierra 2500 4x4 400 1972 ford f250 4x4 390.Tomorrow is the most important thing in life. Comes into us very clean. It's perfect when it arrives and puts itself in our hands. It hopes we've learned something from yesterday. John Wayne
1967gm4x4 is offline   Reply With Quote
Old 02-09-2013, 08:40 PM   #3
bodyman9174
Re: emission delete
The distributor does not have a vac line going to it. Yeah I need to pick up a Chiltons
Cars i have done
Old 02-09-2013, 08:43 PM   #4
1967gm4x4
Re: emission delete
I'm not too familiar with v6's, do you have any pics of the motor and engine bay?
Old 02-09-2013, 08:48 PM   #5
bodyman9174
Re: emission delete
Yeah I can post some. Yeah me to only have had V8's never had any probs taking all the emission stuff off
Cars i have done
Old 02-10-2013, 10:38 AM   #6
pwradder
pwradder's Avatar
Re: emission delete
sounds to me like you're talking about two different things, the only reason i can think of to replace the carb and dist. is to get rid of the esc and mixture control. if you want delete the emissions all you need to do is remove the smog pump,egr,and associated vaccum lines. the electronic spark control and factory carb should still work correctly with no emission system. hope this helps.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 02-10-2013, 10:48 PM   #7
bodyman9174
Re: emission delete
Yep Thanks that what I ended up doing today. What a pain
Got it running again with no service lights on
thanks jay
Cars i have done
